Results 1 to 10 of 24
July 2nd, 2014 11:37 PM #1
Good day Tsikoteers!
I have a problem with the front suspension of my '99 Mitsubishi Spacewagon. The rainy season has started and so with the irritating squeaking sounds coming from my car. I had it checked by all the mechanics I know here in our town but to no avail.
Ball joints replaced. Lubricants sprayed all over. Brake pads replaced.
Please, I need your expert advices before I go into the ditch of useless spending.
Thanks in advance!
July 2nd, 2014 11:55 PM #2
You need to be a lot more descriptive instead of just saying "noisy". How can you reproduce it? Is it continuous noise? Does it happen during acceleration, deceleration, braking, or anytime the vehicle is in motion?
I hope you get the picture...Details.
July 3rd, 2014 12:41 AM #3
What if the noise only occurs during braking or turning? Checked all the supports and it looks fine. Cannot find other reason why I have that "tok" sound on my car.
I may be stupid, but I am not a fool.
July 3rd, 2014 08:53 AM #4
July 3rd, 2014 10:21 AM #5
Sir tanong ko lang po yung boots ba yung rubber covering ng CV joints? Punit na po kasi yung sakin eh. And may sqeaking sound yung front suspension ko kapag dumaan ako ng humps. Although barely noticeable naman yung sound pero naiirita ako kapag naririnig ko. Wobbly steering wheel din po ako. Possible po ba na CV joint din ang sira or tie rods? Thanks..
Posted via Tsikot Mobile App
July 3rd, 2014 10:42 AM #6
Encountered some thug and clug sound in my old sentra before checked all suspension ok naman yun pala yung cross member ang may problema may pinalitan lang na screw at washer konting higpit ayun ok na. You may want to check that part of your car as well.
July 3rd, 2014 11:02 AM #7
July 3rd, 2014 11:35 AM #8
yes, yung cv boots eh yung goma... kung punit na yan, malaki ang chance na may moisture o basa na yung cv joints.
ang cv joints eh puro bearing and puro grasa. pag nabasa, kakalawangin yung bearings... dun nagkakaproblema.
CV failure is recognized by toks.... hindi squeaks.... pag squeaks, nasa ibang joints yan, so kailangan mo pa din ipagawa, at the same time, replace your cv boots and have your cv joints greased, kung ok pa sya.
July 3rd, 2014 11:36 AM #9
July 3rd, 2014 11:53 AM #10
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
