Results 1 to 3 of 3
- Apr 2008
- 51
May 31st, 2011 04:33 PM #1i notice my vios is running rough only when I apply the brakes but it disappears when I shift to neutral (vios matic 2006 1.5g).
initial search for symptoms point to brake booster, vacuum leak daw...
anyone can confirm this?
no other problem with my ride, brakes working fine, just the annoying nginig pag brake to stop, minsan ingay ng hood ko but shifting to neutral stops it
thanks in advance
- Nov 2008
- 641
May 31st, 2011 07:05 PM #3Chief,
Kindly check the following: 1. Brake booster vacuum (as mentioned above, though with the age of your car, mukhang malabo pa). and 2. Idle compensator (Dont know the exact name, but it is the one who adjusts or maintains the idle when a mechanical load is applied, or should I say when you're shifted to "Drive"). Thanks
I guess SMC has been doing a good job selling them
Car Sales Data (2024)
