Results 21 to 28 of 28
January 20th, 2004 09:12 AM #21
Oil leak from shocks should be evident at the shaft and exterior tubes. Madalas kapitan ng alikabok at dumi pag may langis o tagas.
- Nov 2003
- 190
January 28th, 2004 04:35 PM #22Ang KYB ba may fluid type na shocks? I find the gas type too matagtag for my Lancer EL.
January 28th, 2004 05:07 PM #23
Meron po, ang tanong kung may available na exact length and holes for it.
- Mar 2007
- 7
March 7th, 2007 12:54 AM #25Amazon And monroe marketing are both in masangkay near recto. Monroe generally has a softer ride than kayaba. But handling is ok. If your ride is on the heavier side use gas magnum by monroe para mas matibay.
March 7th, 2007 05:16 PM #26
im using monroe reflex in my rears. good thing about this brand on the 323 familia is the catch plate is the same height with the mazdaspeed adjustable shocks which is an inch lower than stock.
from my stock tokico gas shocks, i find the monroe softer.
- Nov 2004
- 115
March 25th, 2007 01:03 AM #27ok kaya monroe para sa pajero? mga how much isa?
dati nag palit ako ng shock kyb sa front.. 1k isa..
now ung likod kelangan ko na palitan, kasi tabingi ung pajero.. parang mababa ng konti ung right side.. possible ba sa shocks un?
March 27th, 2007 11:41 AM #28
ingat lang po sa fakes moroe...
nakabili kami ng fake, akala lang namin mura... ayun... you feel as if nothing is installed at all...
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
