Results 11 to 20 of 21
- Nov 2002
- 7
November 7th, 2002 05:06 PM #11Hi trd888,
Baka sira na yung power steering drive belt mo or baka maluwang lang, higpitan mo or palitan mo power steering drive belt mo pag sira.
baka may hangin yung fluid sa system, i pa-bleed mo power steering system mo.
Baka maluwag lang yung power steering pump mo or baka sira na... check mo rin. Paayos mo kung pwede pa or palitan mo na...
- Jenn
- 17
November 7th, 2002 05:23 PM #12jenn: just replaced my belts. try kong ipa bleed yung system baka mawala yung 2nog.
kung meron pa rin, steering pump na talaga ang may problema. tnx.
November 8th, 2002 04:35 AM #13
Your fluid or your gearbox might be dirty. Heavy steering? Try replacing your fluids. Change your hose lately? Might not be the same OEM size.
December 6th, 2004 04:06 PM #14
Pwede bang e Bleed ang Fluid ng Power Steering? Parang madumi na sa akin
December 6th, 2004 04:17 PM #15
para po sa maintenance gamitin po natin ang Workshop section...
sa tanong nyo, pwede po...have it done by a competent mechanic...
Power Steering Problem
pareng John paki ayos na lang...again wala akong super power eh he he...di ko alam bakit nawala ;)
August 18th, 2007 10:32 PM #16
up ko lang thread na 'to because i'm wondering if anyone here has tried to replace their psf on their own. i'd like to know if an ordinary joe like me can do this procedure because it seems doable naman
- May 2004
- 102
August 19th, 2007 09:53 AM #18
Yes a Joe can do it. It can be messy but not that complicated. Just imagine a radiator drain but in this case you need to really catch the used fluid going out at the same time filling the container with new fluid to avoid air going in the system. Medyo important ang timing since open ang system by the time ma close mo baka lumabas na rin clean fluid kasama ng dirty. Remember that the fluid is high pressure and heats up rapidly.
August 19th, 2007 12:09 PM #19
hmmm...mukhang komplikado din pala. have you done this procedure before bro?
ano problem ng PS unit mo bro?
August 19th, 2007 03:12 PM #20
Yes, but the reason is not to change fluid but to replace an o ring sa fitting ng pump. Ganoon din halos ang nagyari flush, bleed and fill. Ang bleeding ang messy.
