Results 1 to 9 of 9
- Apr 2009
- 543
January 15th, 2010 07:12 PM #1hi fellow tsikoters..
need your help.. napansin ko nung paatras ako ( parking) halos kinabig
ko todo manibela, may tumutunog galing sa ilalim,, parang tik tik tik.
i did look pero maayos naman mga joints ( i mean yung mga rubber buo pa)
what do you think? by the way tunog siya lang when kabig ko to the left.
pag hindi naman sagad kabig wala naman tunog.
thanks
January 15th, 2010 07:33 PM #2
Power steering ba ang sasakyan mo . Check mo iyong power steering hose mo kung worn out na. Kung tunog galing sa ilalim pa check mo na lang ang mga suspension .
- Apr 2009
- 543
January 18th, 2010 12:55 PM #3yes power steering. ride ko crosswind. yung power steering niya wala naman
leak. mahirap lang detect ingay or tik tik tik galing sa ilalim. taka lang ako tuwing
paatras lang ako or parking doon siya tumutunog pero kung halos sagad na kabig. kung medyo kabig lang wala naman.
January 22nd, 2010 11:10 AM #4
January 22nd, 2010 01:27 PM #5
walang cv joint ang rear wheel di ba?
saan po nangagaling yung tunog? sa harap o sa likod?
January 22nd, 2010 02:46 PM #6
check Bushing sa likod
check tie-rod end
nangyari sa akin maingay din pero nakita sa tie-rod
- Apr 2009
- 543
January 26th, 2010 07:06 PM #7yes wala sya cv joint. sige pa check ko muna tie rod bushings..
by the way d ba delikado gamitin kung may sira na tie rod bushings?
puede ba sa highway? im planning kasi pa check ko next month na.
thanks
- Apr 2009
- 543
January 26th, 2010 07:08 PM #8by the way sa harap yung may tiktiktik tuwing on reverse and halos
sagad ang kabig... minsan naman on sudden break meron din pero once lang
yun, para marinig ko uli dapat reverse ako tapos move forward then sudden break lang.
- Jun 2008
- 1,741
February 6th, 2010 02:39 PM #9Baka naman yung stopper sa harapan ay inabot sa saradong kabig (kung may stopper). Pwede rin yang ball joint ay "dry" na, kailangan ng grasa.
yung reverse/forward naman baka sa likuran galing yan, brake shoe baka kailangan ng kunting grasa, nag-iba kasi ng derekson ang rotation kaya gagalaw ng konti ang shoe assy kaya tumutunog.Last edited by weisshorn; February 6th, 2010 at 02:44 PM. Reason: add infos
Maraming Salamat :)
