Results 41 to 50 of 57
- Jul 2009
- 2,618
January 30th, 2023 03:26 PM #41
- 52,517
January 30th, 2023 03:34 PM #42exactly, po!
brake boosters are very long-lived,
and 2.0 variants may be the minority.
why spend good money, stocking up on parts that only a few are expected to look for?
"i wouldn't stock up on parts that will be probably be purchased one piece every five years or so."
"i'd just call the central warehouse, order one, and ask the costumer to wait a month for the part to arrive."
when i buy a car,
my question is, "how common is it?", and not "how rare is it?"
yes, taxi car models are fine with me.
- Jul 2009
- 2,618
January 30th, 2023 04:09 PM #43little side kwento.
2 years ago nasira din ang brake hydrovac nung 2011 Navara ng father ko. wala pa naman overt sign like partial brake loss or spongy pedal other than the hissing sound of air kapag di mo tinatapakan ang brake pedal. once tinapakan ang pedal dun nawawala ang sound. i don't know the exact mechanics of the symptoms pero by logic parang baliktad. anyway ayaw ako pabilihin ng brand new brake booster made in thailand nung mekaniko. he insisted on japan surplus galing ata patrol or urvan. mas tumatagal daw. i did go surplus (around 4k pesos) binigyan naman ako ng warranty ng shop. may konti lang modification dun sa fork attachment ng booster otherwise straight forward replacement. working good pa naman until now.
- 52,517
January 30th, 2023 04:20 PM #44so i am wondering,
can the more common brake booster be modified in some minor weigh, so as to fit the mounting area designed for a 2.0 ?
i am also wondering,
"why did the manufacturer design two different designs, if the two will be doing the exactsame function in the first place?"
or is there a somewhat different functional difference between the two?Last edited by dr. d; January 30th, 2023 at 04:48 PM.
January 30th, 2023 07:52 PM #45
I had a brake booster issue before, it was just the hose. It would take 30 or so minutes to manifest itself
- Jul 2009
- 2,618
January 31st, 2023 10:11 AM #46
January 31st, 2023 12:09 PM #47
February 2nd, 2023 09:35 AM #48
Looks like I've finally licked the car's brake problem, idle drop, and wonky gear shifting In 1 fell stroke.
Sent from my RMX3690 using Tsikot Forums mobile app
- Jul 2009
- 2,618
February 2nd, 2023 11:15 AM #49
- Jan 2008
- 4,726
February 2nd, 2023 01:29 PM #50nabulok na pala yan brake booster mo eh.. buti naka kuha na ng kapalit
lakas maka corrode ng metal yan brake fluid.. kaya nung minsan may maliit na leak yung sa adventure ko, pinalitan ko agad yung seals.. then paint din agad ng brake booster.. kasi natuklap na paint
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
