Results 11 to 20 of 57
- Aug 2019
- 3
August 6th, 2019 05:16 PM #11mga sirs, 96 glxi owner here, problema ko ung brake pedal, biglang tumigas habang nasa byahe. tas pag tinapakan ko ng todo, biglang lulubog ng slight lang, may nadidinig din akong parang buga ng hangin pag lumubog na cia. parang delayed ung pagpreno dahil dun.
na try ko na ung checking ng brake booster ba yun, ung pag tinapakan ung brake tas ini-start e lumulubog pa naman cia.
natry ko na din icheck ung vacuum hose, malakas naman ang intake ng hangin.
may mga trouble shoots pa bang pde gawin bago ko dalhin sa talyer?
fyi mga 3 days din palang nde nagamit ung oto, may kinalaman ba yun? nung inilabas ko e ok pa, pero nung pauwe na e biglang tumigas ung preno. salamas sa mga sasagot sirs, cheers.
- Oct 2006
- 5,693
August 6th, 2019 05:37 PM #12Baka napasukan na hangin ang brake lines? Subukan mo pa-bleed.
- Jun 2005
- 3,772
- Sep 2018
- 77
August 7th, 2019 01:24 PM #14There are several reasons why your car brake pedal is hard. most common would be a lack of vacuum pressure, issues with your valves or an issue on the pedal ratio. You might want to check those areas for possible repair. However, there are other reasons why your brake pedal is hard which can be identified when you had your car thoroughly checked. I think its best to bring your car to your trusted car shop to have it diagnose for possible repair. Doing this will fix the problem accordingly as well as avoid worsening the problem. Hope this helps!
- Dec 2011
- 22
August 7th, 2019 02:49 PM #15Had the same/similar issue/symptoms before with my 90's sedan...
Brake booster ang salarin (not able to hold vacuum, kaya matigas ang pagpreno).
Hope this helps
- Dec 2011
- 22
August 7th, 2019 03:00 PM #16
January 23rd, 2023 04:53 PM #17
Hirap maghanap Ng brake booster/hydrovac Pala [emoji29]
Sent from my RMX3690 using Tsikot Forums mobile app
- 52,729
January 25th, 2023 01:05 AM #19
^ civic fd 2.0 doc
last resort ko na surplus. pero pati ata surplus bihira siya eh.
- 52,729
January 25th, 2023 03:07 AM #20
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
