Results 11 to 18 of 18
October 31st, 2008 12:46 AM #11
Are you kidding!
No one can realign an airbag, an airbag fixed it into your steering. Your problem is very simple dont make it complicated or it will cost you more money.
1. Bring you car back your to the shop.
2. Tell them to center your steering whell before making alignments. There your problem is done.
October 31st, 2008 08:10 AM #12
sir pwede yan dun uli align sa rack end uli but lagyan muna ng clamp dun sa manibela.. hehe d marunong yung nagalign nyan.. pag may airbag.. tangalin muna yung airbag dis able muna bago hugutin yung manibela isang ngipin lng naman yan.. the best dyan.. sa rack end na lng para hindi galawin yung airbag po.. tnx
THE AUTO SPECIALIST
- Mar 2006
- 607
October 31st, 2008 09:10 AM #13pag may airbag ,complicated yan
kailangan mo trained tech ang mag handle ng trabaho
kung minsan kahit trained tech na pag walang scanner , hindi rin basta lang tanggalin ang steering wheel para isentro
October 31st, 2008 09:47 AM #14
tnx, v6!
pero i'm not kidding, just asking! heh-heh.. corny ko..
anyway, what i mean to say or ask is if un nga, would the car require re-alignment, not necessarily with the steering wheel, coz i know the airbag makes it a complicated job.
another question (sorry sa TS, nakaw-eksena ako sa thread mo)...
yun nga pong manibela ko, off-center, as most here have said, probably because of improper alignment procedure. BUT.. why is it that there are times na iba-iba yung degree ng pgka-off center nya? merong sobra, nakaka-distract lalo na when maneuvering sa parking. meron namang instance na onting-onti lng at halos negligible yun pgka-off.
pero palagi namang pa-kaliwa ang tabingi.
does anyone here have a similar experience?
thanks mga masters!
October 31st, 2008 09:56 AM #15
patingin mo muna ang pangilalim mo before pa align at baka meron ng worn out parts like ball joint, kasi ganito ang na experience ko pag tumatakbo naka kabig ang manibela sa rightside pa align ko sana pero tinignan ng mekaniko maluwag na ang ball joint at ng pinalitan pantay na di na kailangan ng alignment.
October 31st, 2008 11:58 AM #16
yup sa akin ganyan din.. kasi sir nagkakatalo yan dunn sa ngipin ng rack end ng car po.. dapat nga po dyan pag kaalign ng , road test agad kasi.. mdali po ausin yan lalo yung technician kukunin nyo masipag ayusin po.. minsan po pag medyo magalaw na yung tie rod nyo nag off center din yan.. tnx
November 13th, 2008 07:07 AM #18
kapag may airbag wag nyo na i-try i-align ang steering wheel sa pag tanggal nito, hindi mo din ma align yun dahil me guide un na walang spline, sa mga tierods lang ang centering ng mga ito.
Yes Yes squeaking sound is heard when shifting only
