Results 11 to 19 of 19
February 2nd, 2004 01:32 PM #11
Wala namang kailangan ilagay na solution or chemicals, basta 1 liter or more dipende sa sasakyan. Patrol ko kinulang 1 liter to flush out the old fluids.
Dami ko na nababasa recommended shop ni speedyfix.
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 3rd, 2004 11:20 AM #12flushing is just removing all of the old fluid by constant bleeding. kumbaga you are forcing all of the old fluid out of the master and the brake lines kaya it take a lot of fluid. normally, old brake fluid is black and new fluid is pink or some similar color. basically kelangan lang bleed ng bleed until the pink fluid comes out.
you can also tell naman kung sira na yung mga brake master kung mahina yung pressure or if it is leaking. pero this has to be checked by the mechanic personally.
you can also check the seals of the front calipers as well as the rear drums. any leaks or moisture that you can see is a bad sign. dapat tuyong tuyo lahat yun.
- Aug 2003
- 9,720
April 5th, 2004 10:41 AM #13just an update...i had the rubber fittings inside my brake master replaced last weekend...all seems fine now...will keep you guys posted; i plan to do some long driving this week. Hopefully this will fix the problem...ang next step kc would be to replace the cylinder itself
September 4th, 2006 05:42 PM #15
nagyari na rin sa akin dati yan. pumunta lng m sa mechanic, bled lang nila kasi daw may hangin. after that ok na
September 4th, 2006 05:48 PM #16
merong bleeder valve ang bawat gulong. have an assistant to step on the brakes. then release, the valve, while the brake pedal was fully depressed. then higpit. check the brake fluid level, add if necessary. do this pattern:
Front Left then Rear Right then Rear Left then Front Right. or anything na simula muna sa malayo...
September 4th, 2006 07:18 PM #17
Nangyari din sakin yan last week. Kakatakot hehe. As in nasa sahig na yung pedal. After bleeding and some readjusting ayos na ulit. Thanks Migs.
September 4th, 2006 10:45 PM #18
sir migs, sakin din buttom down pag unang break or menor. i have to pump twice or more para ma-feel yung pressure. magkano po ba brake fushing sa inyo? tia
- Nov 2003
- 3,849
September 5th, 2006 12:06 AM #19you can text me or call the shop for pricing. the numbers are in my sig.
Maraming Salamat :)
