Results 1 to 10 of 309
- 453
October 30th, 2002 07:20 PM #1some of my friends tell me that to lower cars daw is to buy lowering springs, others say na putolan lang daw.. which one is better? any pros & cons?
- 441
October 30th, 2002 08:54 PM #2go get a lowering springs then cutting your stock springs,coz you will end spending more in the long run,too many components will be affected if you cut your springs.sakit lang sa ulo plus a harsh ride,youll be better off with a lowering springs.
- 121
October 31st, 2002 11:56 AM #3Oh no! :shock:
Don't even think about cutting your springs! This is the absolute worst you can do to lower your car!
Cutting your springs will do funny stuff to spring rates. And cut springs will definitely punish your shocks, whether they are stock or aftermarket.
Sure cutting them will probably be a fraction of the cost of lowering springs, and they might look good with the car standing still, but once you get rolling, oooh boy!
I rode in a car with cut springs, the ride was so horrible, I was dizzy within 5 minutes. The owner of the car junked his cut springs 3 weeks after he put them in.
Save yourself the headache and just get lowering springs!
Good luck!
October 31st, 2002 12:43 PM #4
nope , kung darating time na gusto mo na i disposed sasakyan mo pwede mo pa
ibalik ang oem coils mo . vey harsh ride , sira ang ride comfort at gaya nung unang
reply daming components affected na in the long run gagastos ko doble kasi gusto
maka save sa putol . Pag ipunan mo na lang at it's worth the money spent .
- 453
October 31st, 2002 01:09 PM #5i c, aound ho much ba ang maganda na lowering springs? and may choic ba kung ilan inchs ang drop? kasi balak ko drop mga 3 inchs ung drop
- 121
October 31st, 2002 01:57 PM #6Hey newbee,
Check this thread out. It's got a lot of info -->
http://pinoyforums.com/org/tsikot/viewtopic.php?t=384
3 inches is a lot of lowering though. You might have to with a coilover kit for this, plus a camber kit to keep you from going through your tires like cookie monster going through cookies.
- 453
October 31st, 2002 02:43 PM #7m planning 2 drop my suv at least 3 inches, wat lowering springs do u guys recomend? and at wat shop maganda magawa
- 453
- 41
October 31st, 2002 03:04 PM #9Don't cut your springs! Replace it with lowering springs. When you cut your springs, you lessen its travel and with the same spring rate, it will bottom out when you hit bumps. That is why lowering springs are stiffer to control the shorter travel. You might be able to get away not replacing the old shocks but if they are worn, the ride will be bouncy. Stiffer springs need stiffer shocks or at least not worn. 3 inches is waaayyyy to much drop 2 inches is a lot. You will be altering your suspension configuration. Excess camber will eat up your tires. You might have to spend more $$$$$ on camber kits and coil overs to do it right.
- 453
October 31st, 2002 03:21 PM #102" s a l0t 4 a car, but 4 an suv, i thnk ok lang ang 3"
again, wat lowering springs do u guys recomend? and at wat shop maganda magawa?
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
