Results 231 to 240 of 309
May 15th, 2013 08:03 AM #231
- 52,731
May 16th, 2013 01:33 AM #232putoling springs is always a bad idea. one problem with putol, is that they do not sit well.. think of sitting on a chair with only one buttock, with the other floating in the air. that's how putol spring sits on the spring seats. it can derail on the first serious bump on the road, leaving you with your car body touching the road.
May 16th, 2013 07:44 AM #233
imho, the adventure's height is designed for a purpose. this is to carry huge weight.
bakit kailangan mo i lower?
and yes, no to putol. been there done that. ride is not that good, damages your suspension components, handling gets affected, etc.
May 26th, 2013 02:50 PM #234
How about Lowering Clamps? Ok po ba yung instead na magpaputol? Kasi naka lowering springs na ako ngayon na Tein on my Lancer EX 1.6 kaso kulang sa drop lalo na yung sa harap, unlike used sa 2.0 variant ng EX, well it was actually made for that variant e, pero same body lang naman kaya nagtataka ako bakit iba ang drop. Maybe because mas magaan ang makina ng 1.6? Pero may nabasa din ako sa manual na merong 1.6 na may High Ground clearance, hindi ko alam kung nakaganun yung oto ko. Kulang sa detalye yung sa manual e kaya hirap masabi.
Kaya ngayon naiisip ko na gamitan ko kaya ng Clamp yung front springs ko, madagdagan lang drop kahit 3.4" - 1". Sa itsura niya ngayon parang hindi masyadong nakadrop e. Masama ba itong Clamp? And need pa ba initin ang springs pag ininstall ito? I guess mai-arm lang nila nito sa springs, just tightening the bolts will do to compress eh. So no need to heat, I think :-)
Gusto ko din kasi may option ako to go back sa normal ng Tein ko para maibenta kapag may pambili na ng Coilover. Do you guys think it's fine considering na designed naman for heavier car (2.0 EX) tong Tein na gamit ko so a little compression would compensate or should be fine?
May 26th, 2013 05:00 PM #235
Yup most likely kasi mas magaan yung 1.6L engine. Same sa FD, ganda ng bagsak ng dos litros na Civic.
Benta mo nalang Tein mo kung ok lang. Then swap it with Tanabe DF (if meron available for EX) kasi mas mababa siya sa Tein AFAIK.
I don't really think the clamps are safe. Never heard of it actually, so malamang konti lang gumagamit. If may budget naman pang-coilies why not
May 26th, 2013 09:51 PM #236
May 26th, 2013 10:35 PM #237
^I think those clamps would just degrade and will introduce accelerated metal fatigue in your springs.
Di kaya maxado maliit mags/tire combi mo kaya parang bitin ung drop?
May 27th, 2013 09:57 AM #238
Actually mejo maliit ang overall diameter ko kumpara sa stock ko noon siguro by 1/4 inch. Stock was 205/60/16, ngayon naka 225/40/18 ako. Pero kasi iba talaga ang drop sa 1.6 na variant nito, dahil normally sa gulong na 235/40/18, napakaganda ng drop. Nag 225/40/18 ako pero malaki talaga difference, dapat maliit na difference lang . At merong nag 45 series na kasama ko same variant kame at springs pero yung drop niya hindi pa din kasinganda ng naka 235, normally magrub na yun kapag na 45 series ka pero sa kanya hindi nagrub e lalo na sa rear, dito pa lang masasabi nating iba talaga ang drop samin. Hayy kakainis mahal ng coilover wahahaha Mukhang tyaga tyaga muna ako ah. Naisipan ko lang gumamait ng clamps kasi merong nagbigay sakin sakto 4pcs, pang front ko lang. Kaso mukhang mapapamahal lang ako pagtagal.
- 52,731
May 27th, 2013 11:55 PM #239are those clamps safe for road use? they way i see it, the clamps will just concentrate stress on certain parts of the spring, hastening metal fatigue..
- Jul 2012
- 62
May 29th, 2013 03:47 PM #240Mukhang hindi siya safe.
Mukhang magkakatamaan ang clamps na yan at makasira pa sa suspension ng kotse.
Gnwa ko dati sa civic ko stock SHOCKS at eibach lowering springs. Ayun after ilang months sira engine support, sira shocks pati wheel bearing sira.
Siguro sa bigat ng mags at sa pag drive narin ehhe.
Pero ayun ngayon back to stock height and shocks pati springs hu hu.
sarap ng dalin ang kotse kasi di na parang kabayong tumatalon ahhaha.
Kaya think twice talaga before lowering your car.
Looks vs. comfort ang labanan.
BTW Question lang:
May suggestion ba kayo magpapalit na ung 98 model starex namin ng leaf spring?
Nagiisip kami kung surplus lang or itong tiger leaf spring na ang kunin namin heh.
Any suggestions?
Thanks!
