Results 161 to 170 of 309
July 12th, 2007 04:26 PM #162
may nabanggit saken ung friend ko na pwede daw ilowered ang auto without replacing or cutting the springs. may pwede daw gawin na adjustment lang dun sa "baso" kung san nakapatong ung suspension daw.. not sure what part.. pero has anyone heard of this?
July 12th, 2007 05:02 PM #163
Yes, but that will still result in the suspension bottoming out since your spring rate is still the same but your suspension travel has shortened (unless you have enough clearance for your tires under the fender).
The method you mentioned required cutting the spring perch from the shocks and welding it back on at a lower position. This is something like a low cost version of a coil-over spring setup. But would you trust your ride on some spot welds that could break at the worst possible moment (like when you are heavily loaded or cornering hard)?
July 13th, 2007 08:33 AM #164
October 25th, 2007 11:12 PM #165
buhayin ko lang to, may nabasa ako dito somewhere na yung sa lovelife corolla, ay may lutang effect kapag mabilis na takbo, at solusyon ng iba ay ilowered yung sasakyan sa harap.. naexp ko din to sa lovelife altis ko at around 90-100kph or more, so since mahal ang lowering springs, ok lang ba ang putol kapag .5 inch lang ang ibabawas, ayoko naman kasi ibaba ng 1 inch or more dahil parang di na ok.. yung sa iba naman kasi grabe 1.5 to 3 inches parang sobra.... thanks in advance
October 26th, 2007 12:17 PM #166
Don't.
If you feel the front end is too floaty at high speeds, upgrade the front shocks to better ones to make the ride more controlled.
December 2nd, 2007 05:33 PM #167
may naka try na ng zee kind of lowering?
http://www.mymitsuph.com/index.php/topic,7353.0.html
December 6th, 2007 03:30 PM #168
Lowering springs na. Konting gastos lang pero sigurado ka naman. Mahirap i-try yun mga putolputol na mura, sigurado mapapamura ka pag lumaki ang diperensya.
- Oct 2007
- 50
March 10th, 2008 01:46 AM #169hmm nbasa ko lng dto mga bro, e dapat ba tlgang mg palit ng sport shocks kung mgpapalit ako ng H7R lowering springs? hndi ba ok na ung stock shocks ko parin gamitin ko?
March 10th, 2008 09:08 AM #170
It depends. Depends on what level of H&R you get... if you get the race springs, absolutely not. If you get "just" the sports springs, your original shocks should last a while. But if your shocks are already on their way out, or if you combine the lowering springs with heavy mags (like 17"), your shocks may not last very long.
It'll depend on use, too. If you drive over a lot of rough roads, that'll accelerate the wear on your shocks due to the lowering springs.
wala kasi kwenta kahit ano pa tollroad yan eh kung sabay-sabay kayou uuwi. Ang lunas talaga jan...
Traffic!
