Results 1 to 2 of 2
- Jan 2009
- 35
March 28th, 2012 10:39 AM #1Mga Sir,
Patulong naman po.. May loud squeaking noise kasi na nanggagaling mismo sa steering wheel eh. Pero sa labas wala naman. Ung power steering fluid ok naman ung level including belt ok naman ung tension. Nag-start ung ingay after 20 to 30 mins of driving from cold start. Then tuloy tuloy na yun maghapon. Even when the engine was turned off and try to move the steering wheel from left to right ganon parin. Ano po kaya ang possible na problema? Sobrang nakaka-irita na kasi eh..
Marami marami salamat po in-advance..
March 29th, 2012 03:02 PM #2
try spraying the gap between the steering wheel and the steering column cover. your objective is to lubricate the contact between the horn contact pin and the horn contact ring. this should only be the sliding surfaces in the column and it dries up once the car has aged
