Results 1 to 5 of 5
    Eto storya:
    Lite Ace breaks lumulusot for the past 2 months pag hard breaking. Pero di nauubos yung fluid.
    Finally pinadala ko sa Driver ni ermats sa shop last saturday morning (Tiremaster Servitek Sucat) para pa check. Sabi kailangan repair kit sa Brake Master. Bili ako along with other parts (Engine Support, tune up kit....kailangan na din palitan). It was finished after lunch and ginamit nila the whole afternoon ok naman.
    Sunday and MOnday di ginamit yung LiteAce.
    This morning nung gamitin nila, naninikit lahat nung preno. Pinakita sa isa pang Servitek sa Alabang (Sis co. daw nung sa Sucat). Binleed etc...ganon pa din. Sabi Brake Master na daw.
    Di kaya masama gawa doon sa overhaul-kabit repair kit?
    If ever magkano kaya brake master for this type of vehicle?
    Thanks in advance sa mga reply!
    Nov 2003
    minsan, di nakakayanan ng repair kit lang kasi may ukit/kain na yung cylinder ng master. this is the reason di na makaseal ng mabuti yung bagong rubber dun sa repair kit.
    Di naman kaya baliktad pagkakalagay ng goma? That's quite odd to be stuck after being serviced.
    Drain/Replace brake fluid. Baka di nagawa nung i-install ang repair kit.
    Thanks for the replies...yung ROD daw sa may Brake MAster sumobra pasok...yun inadjust ok na....
Lite Ace - Brake Master/Hydrovac kaya?
