Results 1 to 3 of 3
- Jan 2008
- 26
August 15th, 2008 08:39 AM #1I lifted mg Frontier by installing longer shackles at the rear and adjusting the torsion of the front suspension. at gained 2" and 1.5" respectively. The problem was the front tires is not cambered correctly, it is wearing out unevenly in the inner side of the tires. It was wheel aligned and cambered by computerized shop. What is the maximum height adjustment of the torsion of a Frontier 4x2 ride? Some have same experience same as this? tnx
August 15th, 2008 08:54 AM #2
My assumption is, your problem could be incorrect toe settings, not necessarily incorrect camber.
Both negative camber and toe-in can contribute to accelerated tire wear on the inner shoulders.
This is just a hunch. Correct me if I'm wrong.
THE AUTO SPECIALIST
- Mar 2006
- 607
August 15th, 2008 10:59 AM #3then your camber is not set properly
would be nice if it can be set at +/- .5 degree
