Results 1 to 5 of 5
- Jan 2011
- 262
October 13th, 2011 04:19 PM #1Help please gurus,
I'm currentyle experiencing lagutok sounds while turning at above 20 km/h, but when I turn to the left or right at low speeds no sounds can be heard.
Is this a CV joint problem? that's what I have read from a number of forums.
Please help me guys..
October 13th, 2011 04:34 PM #2
- Jan 2011
- 262
October 13th, 2011 05:09 PM #3Sir, I also tried turning my steering wheel from full left to full right but I didn't hear a thing. Is this still considered a CV joint problem?
When I'm driving on a straight road, the sound is also intermittent. When I hear it, I take my feet off my gas pedal and the sound is gone.
The sound is also imminent when I turn while pressing the gas pedal.
If I take my feet off the gas pedal or step on the clutch, the sound dissappears.
Please enlighten me before I go to a mechanic.. thanks!
October 13th, 2011 05:27 PM #4
Have the following checked too:
engine mounts - worn engine mounts can cause the engine to shift slightly resulting in mis-aligned drive axels.
front suspension bushings - worn out rubber bushings (top and bottom) can also cause a degree of drive axel mis-alignment and also intermittent metal-on-metal knocking sound.
- Jun 2010
- 5
October 31st, 2011 02:47 PM #5Baka velocity yan. Better have it checked, mura lang pagawa nyan mga wala pa 1k. Ganyan din sakin, kaso I get that everytime I make a turn tapos im too slow tapos medyo di pa nabibitawan ang clutch. Try mo bitawan clutch tapos press on the clutch again nalang kapag nakaturn na.
Maraming Salamat :)
