Results 21 to 30 of 34
- Apr 2012
- 80
March 8th, 2018 02:02 PM #21
- Jul 2017
- 14
March 10th, 2018 04:06 AM #22Same tayo ng experience sir. May kabig din yung auto ko sa left na dati wala naman. Ayun sinabay ko na sa pagpalit ng 2 front shocks KYB pang vios Robin 2150 each and shock mount 600. Sabay align na rin pero may kabig pa rin. Hanggang sa nirecommend na palitan na yung gulong ko 4 tires kasi pag check namin 2012 pa yung production date 😱 so ayun. After magawa replace 4tires grabe ramdam ko gaan na steer tsaka wala na yung ugong noise kahit patag kalsada. 11k inabot po nung tire westlake 215/45r17 ok na po ba yun rate ba yan? Di po kasi ako maalam sa presyuhan.
- Apr 2012
- 80
March 13th, 2018 04:57 PM #23
- Jun 2008
- 1,741
March 13th, 2018 07:19 PM #24
- Apr 2012
- 80
- Mar 2018
- 2
March 16th, 2018 09:19 AM #26Hi Guys, same problem sa kotse q kapag nilagay m ung steering wheel na naka straight lumiliko din cya sa kanan pero okay naman ung gulong at ilalim q. Palagay q camber, alignment lang kailangan. Baka meron kayo alam na maayos gumawa around sa Santa Rosa, Laguna? Dun kasi ang location q. Salamat.
- Oct 2020
- 7
October 19th, 2020 02:57 PM #27Reviving this old thread in hopes na may makatulong sakin , have the same problem as OP kusang kumakabig ung steering wheel pa left kapag umaarangkada (mga 40kmh+ bilis) na.
Backstory: Napansin ko na tong issue na to everytime na magpa-wheel rotation (freebies ksma ng change oil) kaya simula nun ma encounter ko un di ko na pinapa wheel rotate, na running flat kasi ung right tire nya at pudpod na ung logo sa side wall ng gulong, kaya naisip ko that time baka may diperensya na sa gulong, fast-forward to this month na flat ung right tire may bukol na at pinalitan ng 2nd hand na gulong (courtesy of local vulcanizing shop), then ayun nakabig na talaga sya, akala ko off lang alignment nag pa align na me at wala talaga ganun pa din, kaya naisip ko na bumili nalang ng gulong since 6+ years na dn ung current na mga gulong, kahapon nagpalit na ako ng gulong Yokohama 185/55/R15 (courtesy of Mindanao TyreHaus) same specs sa stock, then alignment, but sadly, gnun pa din, pina road test ko dun sa nag align sa shop nakabig talaga, inadjust ung camber para ma kontra ung pagkabig sa left, pero same result may kabig pa din, pero nabawasan ng konti.. Ang ending sabi nya need na daw magpalit ng Shock Absorber.
TLDR: Kusang kumakabig pa kaliwa ang steering wheel, wheel alignment correct, nag adjust ng camber, next step mag palit ng front shock absorber.
P.S: Ayun pala pansin ko din na sobrang tagtag na nung kotse kahit konting lubak, yung tipong parang may mini lindol (OA sa lindo, pero maalog talaga) sa loob ng kotse kpg malubak kalsada..
October 19th, 2020 03:42 PM #28
based on your story.
bagong tires (all 4???)
bagong align and camber
car year and model?
kelan ka huling nagpacheck ng brakes?
- Oct 2020
- 7
October 19th, 2020 04:20 PM #29
Yep all 4 tires bago, align and camber check, Ford Fiesta 2014 1.5L Trend HatchBack, last March 2020 kasabay ng change oil (free kasi ung brake cleaning), wala naman sinabi si suking auto shop regarding sa brake, kasi kasama sa PMS iniinspect nila yun eh, iniinform naman nila ako kung may kelangan palitan (like filters, spark plugs), at nung March 2020 di na kasi ako nagparotate ng gulong, since nung last 2 PMS ko before march everytime na i-rorotate ayun kumakabig pakaliwa, kaya akala ko talaga that time sa gulong ko talaga may problema .
October 19th, 2020 04:31 PM #30
hmmm. kuha ka ng tape measure, check mo if same yung wheelbase mo sa left and right side
kung pantay din... wala na akong maisip na problem
