Results 11 to 18 of 18
Tsikot Member Rank 3
- Dec 2002
- 636
September 25th, 2003 09:26 PM #12
sa steering rack siguro, does it feel like something is not fastened well. sa service ng bank na corolla before ganyan din sa steering rack ang problema.
September 26th, 2003 11:55 AM #13Originally posted by peter
Actually, I also had it checked, ok pa naman daw. I can feel it sa steering wheel everytime i drive. Minsan there's a "Tok" sound.
I'm really having a hard time, i really get irritated everytime i hear or feel that.
www.toyotautoclubphil.com
My car is a Lancer and don't know much about Toyota, but from the way you described the problem ("TOK" sa steering wheel) it seems pareho tayo ng problem ko noon.
In my case the culprit is the coupling at the base of the steering column. The Lancer's steering column coupling is not replaceable, (the whole column should be replaced) so what I did is have the coupling spot welded sa steering column and nawala na yung "TOK" sound.
Now my suggestion is have your steering column coupling checked, normally inaalog nila yung base ng steering column to check it, there should be no play kapag inalog or have the steering column dismounted (madali lang yan) so you can thoroughly inspect it.
In some cars, like some models of Honda, napapalitan ang coupling lang, maybe pwede din sayo na coupling lang ang papalitan and not the whole column.
HTH.
September 26th, 2003 12:39 PM #14
di kya, baka bato lang na tumalsik sa ilalim ng car mo yun?
"tok" din ang sound nun.
try mo din sa vc joint, kpag sira na ksi yun, may "tok" sound din lalu na kapag lumiliko ka.
September 26th, 2003 02:02 PM #15
peter:::check/replace your rack and pinion and steering bushing. yun corolla xl big body ko (nakita mo yun diba?) yun lang ang madalas pinapalitan. Twice ko napalitan yon during the 3 1/2 yrs that it's been with me. The first is when it was still under warranty and the second before I sold it.
- Sep 2003
- 53
September 28th, 2003 12:05 AM #16I already had my steering bushing column replaced 2 weeks ago.
Have'nt check the Rack & Pinion. Sometimes, i'm really wondering, bigla naman sya nawawala lalo na pag smooth ang takbo nya. Anyway, i'll be considering your suggestions and thanks a lot for the advise.
www.toyotaclubphil.com
- Sep 2004
- 34
February 22nd, 2005 08:18 PM #18mga sir pano kaya sa lancer gti almost the same as problem kay peter ,pag malapitan lang ung driving ok smooth la naman langitngit kaso pag long drive na nagkakaron sya ng langitngit specially pag dadaan sa lubak...mga sir baka pwede nyo ako bigyan ng idea....tnx
doc, in first world testing kahit walang itim na usok eh bagsak talaga diesel remember the...
LTO accredited emission testing centers
