Results 11 to 20 of 20
April 21st, 2008 10:39 AM #11
April 24th, 2008 10:48 AM #13
- Nov 2006
- 299
April 24th, 2008 12:56 PM #14theres a lot of things to consider when the vehicle is either pull to the right or left and im sure that you are familiar with the road cone effect, also tire pressure better check it first, mismatch tire,defective tire or wheels.think about if you happened to run over or hit the curve before.
best thing to do first is to switch your front wheel assy from left to right and right to left and see what happen.if your concerned dont change then you might have a problem with alignment,this include suspension and steering system.
another best thing to do is to have your vehicle set at the alignment rack and ask for before the adjustment and after the adjustment reading,im sure they will give that,and then test drive the car again and if it still pull,this time align your car and compare your previuos reading to the last reading which side has an excessive change and consentrate on that side.
note; tire balance has nothing to do with the pulling concern.before they do,you will feel the vibration first.
April 24th, 2008 01:04 PM #15
dalhin mo sa servitec. don't mention anything basta kamo papa-check mo lang ang alignment. hingi ka rin ng quotation / estimate then compare mo dun sa unang gumawa.
- Nov 2006
- 132
June 6th, 2008 07:15 PM #16Ganyan din problem ko ngayon sa ride kong gen1 pajero. Kumakabig sa kanan kapag binitawan mo ang stering wheel. Kaya ayun kahit na straight ang road kinokontra ko yung manibela para straight ang takbo.
ano kaya dapat ko ipa-check dito.
pareho naman front tires ko ng brand at pareho din ang thread.
June 6th, 2008 08:19 PM #17
Both of you, I know what are you trying to say. It happen to me also before in my car.
You have a bad wheel bearing. When I change the wheel bearing I solve my problem. One more that pulls wheel's realy bad is the brake caliper sticking on it.
- Nov 2006
- 132
June 11th, 2008 11:04 PM #18
June 17th, 2008 10:03 AM #19
Ask ko lang pano ba nagreresult sa ganito ang Cars natin?
Dahil ba sa Evryday Lubak and daanan?
Dahil ba sa nadamage lang sa katagalan ng sasakyan?
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 29th, 2008 04:36 PM #20yes, normal wear and tear. drive slower and more maingat and it will happen later pero mangyayari parin.
Hybrids and EV
