Results 1 to 9 of 9
- Mar 2007
- 63
July 19th, 2009 08:00 PM #1Guys, yung kotse ko parang may kabig sya and mabigat dalhin yung manibela lalo pag sa straight nakakabig ng konti sa kanan yung manibela. kaya lagi akong bumabawi sa left para gumitna ang andar ko.
Nagpawheel alignment na po ako and camber nung 110k kms (115k kms ang odometer ko ngayon)and hindi pa ko nagpalit ng gulong and mags since then.
although, i felt this problem nung pa refill ako ng shocks ko sa harap...
bakit kaya guys?
July 19th, 2009 08:55 PM #2
You can only do a wheel alignment if your tires are relatively new or really new. It is because if your tires are worn unevenly, any wheel alignment done will be useless.
July 20th, 2009 12:30 AM #3
Pa check mo muna yung gulong at mags mo. Baka me problem na. Kung wala at nag camber alignment kayo di baka wheel alignment. Some cars need both front and rear alignment. Yung akin dati mabigat steering wheel at me konting kabig sa kanan. After front and rear wheel alignment (yung me digital alignment wag analog) nawala plus super lambot na ng steering wheel.
- Apr 2009
- 543
July 21st, 2009 10:11 AM #4hello... singit lang ako. yung sa akin uneven sya sa right front side..
so you mean kahit pa camber or allignment ko useless din? ang ginawa ko muna binabaligtad ko, inner ko outer na, pangit kasi yung outer pudpod na.
July 21st, 2009 10:17 AM #5
kung hindi makuha sa camber at wheel alignment, better check yun ball joints mo and bushings. possible na dun ang problem kaya hindi makuha
July 21st, 2009 07:34 PM #6
Sir,
Kung nagpa refill ka ng shocks sa harap, baka yung shocks mo e hindi pantay pagkakagawa...pa check mo na lang. Mas mababa yun dun sa side kung saan kumakabig yung manibela mo...patingnan mo na lang.
Hope this helps..
- Jul 2009
- 11
July 23rd, 2009 12:50 PM #7Correct po ang suggested solution..camber, alignment then isama mo na rin balancing bro!
After that cool straight na naman takbo ng ride mo! Hope this helps.
July 23rd, 2009 01:47 PM #8
- Jul 2009
- 2
Ayos sumabay pa sa Greenbelt 1.
Makati CBD parking
