Results 1 to 6 of 6
- Nov 2007
- 28
April 8th, 2008 02:59 AM #1hi guys, is there a way to drain power steering fluid without disassembling the whole steering system......... i mean parang nag drain ka lang ng engine oil or radiator wherein may valve lang or nut na i-unscrew tapos pde na idrain...
thanks!!!
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 9th, 2008 01:29 AM #2remove the return hose and start the car para umandar yung pump. then keep adding to flush it. when you return the hose just top up.
- Nov 2004
- 141
April 19th, 2008 12:52 PM #5
lift the front. with the engine off, have someone turn the steering wheel left to right a couple of times until the bubbling sound that you hear in the reservoir disappears. start the engine then top off with PS fluid until the required level is reach.
- Nov 2003
- 3,849
April 29th, 2008 09:07 AM #6tama, just turn it back and forth and that's all the bleeding it needs.
Traffic!
