Results 1 to 5 of 5
- Oct 2008
- 23
November 26th, 2008 08:30 PM #1Medyo baguhan po ako. My car is 2001 honda city type z vti. May narinig ako ugong sa power steering when i tried parking paurong tapos medyo matigas manibela. Check ko ps fluid puno naman. Madali lang ba check kung may leak? Immediate problem po ba ito or pwede ko pa pagtagalin ng weeks?
November 27th, 2008 04:49 AM #2
First check you power steering fluid. If low, add fluid to the level if over filled remove excess fluid if none of the above bleed you power steering by turning your steering wheel from left to right lock to lock. Do this for several times.
Oh one more thing, when doing this your car engine must be on and park, do not drive while doing this.
- Oct 2008
- 23
December 6th, 2008 06:24 PM #3Salamat sa reply. Actually i've no confidence in checking the leak myself so when i went to have my power window fixed, pinacheck ko na rin sa mechanic kung may leak nga. He said wala naman daw but he adjusted something in the fanbelt and the ugong sound i was hearing seems to be gone. That was yesterday...I will have to observe pa kung la na nga.
December 6th, 2008 08:50 PM #4
- Aug 2007
- 72
August 19th, 2009 09:27 AM #5question po.. my power steering fluid is now at minimum level.. im not sure what brand of PS fluid i should buy. i have honda city exi 97 car. hindi ko rin alam ang brand na nakalagay sa tank dahil second owner ako.. ok lang ba imix ko ko ang iba brand? or kelangan muna idrain? TIA
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
