Results 1 to 5 of 5
- Nov 2007
- 6
September 25th, 2009 02:36 AM #1I need your advice fellow tsikoteers:
I was driving last night sa SLEX. Akala ko nung una malubak lang yung daan kaya nagwiwiggle yung steering wheel, however, habang tumatagal mas lalong gumagrabe yung wiggle, so i thought na flat-an ako ng gulong. So I stopped and checked the wheels - ok naman lahat. Tapos pag shift ko ulit sa 1st gear, ayun na naman nanginig ulit yung steering wheel, anlakas habang papa-accelerate! so nag full-stop ako, then accelerated slowly hanggang makasecond gear ako, then bigla umayos na.
I had it checked checked the next day sa shell - ok naman daw yung gulong, walang sira sa ilalim at ok naman daw alignment, baka nalubak lang daw ako.
I convinced myself na baka nga guni-guni lang. Pero on the way home today, I tried again to recreate yung pag nginig ng steering wheel. from 90kph, I started to decelerate by not pressing on the gas (pero ndi ako nag b-break), then i put the gear to NEUTRAL. ayun, may tumutunog (not sure kung sa transmission - but definitely not sa engine). mag gas ulit ako, then decelerate ulit, put the gear again to neutral - ayun! palakas ng palakas yung tunog, until bigla nanginig na yung steering wheel.
mejo nagpanic ako so tinabi ko yung kotse - full stop. then proceeded driving ulit. ayun, maayos na sya.
WHAT COULD HAVE BEEN CAUSING MY STEERING WHEEL TO WIGGLE???
September 25th, 2009 09:05 AM #2
anong speed mo nararamdaman yung wiggle? from 90 kph downwards lang ba? what if you are accelerating? meron din ba?
- check your tires, baka na oblong o may bukol.
- check also your inflation.
- check mo din yung rims, baka na oblong dahil sa lubak.
- check mo din yung wheel balance. the lead could have fallen off.
pag wala dyan:
- alignment
- suspension issues na yan. most likely tie-rods or yung steering linkage.
- Nov 2007
- 6
September 25th, 2009 10:57 AM #3pag mabagal lang sya nagwiwiggle, tapos not everytime. bago yung 4 na gulong ko, wala pang 3 months, so i doubt na sa gulong. siguro nga sa may suspension.
sana umabot pako sa opisina mamaya. papacheck ko sa sabado. thanks!
- 194
September 28th, 2009 12:25 PM #4what are the consequences of running on oblong tires? how soon should i replace oblong tires?
September 28th, 2009 12:34 PM #5
Monk-owned R53
