Results 1 to 7 of 7
January 2nd, 2006 05:02 PM #1
Ei fellow tsikoteers..I just want to ask for your good advices, i hear squeakssss on my steering wheel everytime i turn it. Naglagay ako 3 days ago ng power steering fluid ganun pa rin my squeaking pa rin ako naririnig. help guys... Tnx.
January 2nd, 2006 05:12 PM #2
baka kelangan linisin ung power steering pump mo. had a similar problem. may umuugong kapag pinipihit ung manibela kahit konti either way. saka parang hindi ganun ka-fluid ung pagpihit ng manibela. pinalinis ko sa cruven. 1,600 ang cost. so far ok naman. hope this helps.
- Feb 2005
- 99
January 3rd, 2006 06:02 PM #4pag squeeks i think the problem is with the power steering pump na. Pag nagkakaroon ng high pressure sa pump (everytime you turn), nag si-sieze yung pump mo so yung belt mo slides and causes the squeeks. Normally, indications of a busted pump are leaks sa pump at tigas manibela.
January 3rd, 2006 06:41 PM #5
Tnx sa mga advice dudes! Hindi ko pa kasi mapa check sa auto shop. Last night may sinabi ng cousin ko re squeakkk, possible din ba na (aside sa PS pump) tie rod or ball joint or CV joints can cause the problem?
January 4th, 2006 09:24 AM #6
kung CV joint kase, ang tunong nyan ung 'tok tok tok' kapag nakapihit talaga ata ung manibela. nangyari na din sakin yan kaya pinapalitan ko both joints. 1k plus per cv joint sa cruven ko pinapalitan. after nun wala na ung 'tok tok' sound.
- Sep 2005
- 103
January 4th, 2006 04:01 PM #7i analyze mo muna mabuti kung san talga nanggagaling ung squeaking sound, pwedeng tama si wax na ung belt mo ung tumutunog kapag nag seize ung PS pump ng sasakyan mo. un bang tunog ay lumalabas kapag nagtu turn ka ng manibela o kahit nakapihit na ung manibela may squeaking sound pa rin? isa sa mga possibilities na pwede mo tingnan.
