Results 11 to 20 of 20
June 1st, 2008 10:51 AM #12
sir hindi kaya mas mataas lang yung right than the left kaya sa tingin parang mas nakalabas yung right side?
try niyo sukatin kung magkaiba talaga... kasi sa ek natin talagang mas bagsak ang left side sa right. normal po ito...
- May 2008
- 10
June 2nd, 2008 03:23 PM #13
- May 2008
- 10
- May 2008
- 10
June 2nd, 2008 03:37 PM #15Questions you need to answer:
1. Do you use spacers?
-well, not that i'm aware of.... mukang wala namn sir
2. If so, did the mechanic install them prior to installing your new tires/[COLOR=blue! important][COLOR=blue! important]wheels[/COLOR][/COLOR]? n/a
3.If not, are you sure the car hasn't been in an accident?
-Nabanga na ko sir. same side kung san nakalabas yun gulong. although there were no repair that was made, all replacement.
4. Can you check if both [COLOR=blue! important][COLOR=blue! important]front [COLOR=blue! important]fenders[/COLOR][/COLOR][/COLOR] are in good nick - meaning no dents, no accidents, etc.? It may just be an illusion with a recessed fender.
- wala naman sir... mukang pantay naman fenders ko... palit din kasi yun nung nabangga...
5. How long ago has this been?
-hat was way back 6-7yrs ago
What are the alignment specs? Condition of your suspension? Worn bushings? Toe specs of front wheels?
i need to check on the alignment and toe specs from servitek i will post it here asap...
- May 2008
- 10
June 2nd, 2008 03:41 PM #16
June 2nd, 2008 05:56 PM #17
ang tanong pantay ba pagkaputol? usually kung putol mo kasi right, ccounter pa din yung left. ginawa ko na din dati yan sa EK ko with adjustable springs.
to cut the story short... measure ako then adjust pero bilang hindi ulit pantay... bale adjust ako right side the yung likod naman na left ang higher... actually theres no remedy for the prob unless sobrang tiyaga magadjust. yung friend ko sakto pero took him 5-6 hours para lang pumantay.
usually parang mas nakalabas talaga tignan yung sa right than the left... measuring tape mo yung layo ng wheel sa fender. dun mo makikita kung ano talaga... pero feeling ok lang yan. wala naman ata ginalaw except for the mags and springs di ba?
- May 2008
- 10
June 3rd, 2008 01:58 AM #18hmm... can we post pictures here? if so, ill try to take a picture of both left and right side... then tell me if that's normal....
btw hndi halata or close to no diff pag tiningnan from the top view (sa fender) ... but there's an obvious difference when you view it from the front (sa bumper)
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 3rd, 2008 09:31 AM #19maybe wrong offset.
could also be na nabanga yung car kaya labas yung suspension.
June 4th, 2008 08:03 AM #20
Pics are worth a thousand words. Antayin namin pics mo, so we can see for ourselves. Take lots of pics at different angles.
The misspellings on that page are so funny! "Nono-Ceramic" "In-Fared Multi Layer" :twak2: :grin:
