Results 21 to 30 of 36
- Aug 2003
- 11
May 11th, 2005 01:34 PM #21Originally Posted by mazdamazda
Check this:
http://www.goodyear.com.ph/service/warranty.html
Maganda yung road hazard protection plan ng Eagle F1. Any other tiremakers have the same type of warranties here? Or is the warranty dependent on the dealer? Sayang walang for 14 ang F1
Thanks
May 11th, 2005 01:40 PM #22
In terms of technology... mas advanced yang Eagle Ventura (kalalabas pal ang niyan). While yung Dunlop & Yoko choices mo medyo luma na...
Problem ay wala pang may first hand experience sa Ventura. Yung mga lumang Goodyears kasi (NCT3) ang ingay tapos bukulin...
May 11th, 2005 01:43 PM #23
correct maingay ung mga NCt3 ...
yaw mo magtry ng bridgestone? i'm using potenza g3 and ok naman ung kapit nya.
May 11th, 2005 01:45 PM #24
godyear ducaro ga oki
wag ka mag yoko s306, pot-su..ganyan tires ko before my ducaros e..
May 11th, 2005 01:46 PM #25
AFAIK good year lang nagoffer(sofar) ng 5-yr warranty. Due for replacement din kasi yung sa isa naming car. planning to get the F1 kaya lang yung 225/45 R17, currently on continental contisport - dami problema nito!!! So back to goodyear talaga ko. For the 14 or 15s, OK na yung goodyear imo.
- Aug 2003
- 11
May 11th, 2005 10:56 PM #29
Medyo matigas at maingay ang Potenza G3, but if you don't mind that, the tire is good.
By the way, how does this tire compare to Neovas, in performance, grip and tread life?
May 12th, 2005 12:06 AM #30Originally Posted by ILuvDetailing
...reasonably priced pa, got my LM702 for 4.8k/each. r17/45/215.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
