Results 1 to 10 of 10
- Nov 2012
- 12
December 16th, 2012 01:24 PM #1Mga Sir pahelp sa auto ko (Hyundai Getz) lumalagutok kapag nagdadrive na ng mga 10-20mins, dati pag kumakaliwa lumalagutok din pero napalitan na tie rod at wala na lagutok pag turning, pero ngayon naman kapag nagdadrive ka at lagpas na ng 10-20mins may lumalagutok na, pinalitan na shock absorber, ano po kaya prob nito? sabi nung mekaniko baka daw coupling, need help guys!
- Nov 2012
- 12
January 2nd, 2013 04:06 AM #2Ako lang ba nakakaranas nito? BTW may lagutok parin kapag kumakaliwa kahit nakafull stop. Ano kaya to? Ang malas ko naman.
- Nov 2012
- 12
January 2nd, 2013 07:52 PM #4
January 2nd, 2013 08:52 PM #5
Techbically, whatever component in the suspension it is, it should be noisy from the start.
If it takes ten minutes for the sounds to start, something is heating up and coming loose. could be on the transmission side or could be a fluid shock overheating... But a bad shock would easily be felt by the uneven bouncing of the car over bumps.
Which corner of the car is the sound coming from?
January 2nd, 2013 10:22 PM #6
- Nov 2012
- 12
January 3rd, 2013 12:44 AM #7Tingin ko sa front driver side, ngayon kapag kinakabig ko manibela full stop after 10-20min drive(basta tumagal na) may toktoktok na sound, napalitan ko na 2 shock absorber sa harap, tie rods, ano pa kaya possible na culprit? pag sa transmission ung prob ano ang common symptoms sir?
Gas shock nga pala pinalit.
- Nov 2012
- 12
January 3rd, 2013 12:46 AM #8
- Nov 2012
- 12
January 5th, 2013 12:16 PM #10Possible ba talaga na cv joint? Parang nabasa ko rin kasi sa net na kapag sira na cv joint sa umpisa palang matunog na. Natanong ko na kung magkano cv joint sa petron fairview 2k daw yun part at 350 ata labor or 400 nakalimutan ko sinabi nung mekaniko.
EDIT: Makatarungan ba yung 2k na cv joint?
Latest mileage:
