Results 11 to 13 of 13
October 5th, 2006 04:28 AM #12
That really shouldn't be the case if your front brakes are disc. Remember that the braking power ratio is about 75-80% front and 25-20% rear. Unless your model or same platform vehicle was made with a disc there really won't be any direct bolt on rear brakes. Even with a donor vehicle you'll still need to open your diff and pull your axle shaft to change to a disc. A front drive vehicle would be easier to convert the rear than a rear drive.
Here is a link to a conversion for a Ford Explorer 4x4 to give you an idea of what needs to be done.
http://www.explorer4x4.com/discswap.html
October 6th, 2006 06:36 PM #13
thanks redorange,
looks like ill be sticking with the drums, I kinda overlooked that my rig was rwd pala mukhang marami ngang gagawin as I have to remove the rear axle pa and to convert it to fit with the disc
Monk-owned R53
