Results 11 to 20 of 24
August 20th, 2019 07:39 PM #11
August 20th, 2019 07:53 PM #12
August 20th, 2019 08:07 PM #13
August 20th, 2019 08:13 PM #14
- Jul 2009
- 2,618
August 20th, 2019 08:49 PM #15mano-mano is fine. any mechanic worth his salt could do this job correctly. bleed the system enough and you could potentially replace all the brake fluid in the system. ang nakikita ko lang sa vacuum na advantage ay pwede kang mag bleed ng brake system mag isa as opposed to a two-person job of "bomba" - "pirme".
August 20th, 2019 09:00 PM #16
Pwede diy 1 person.
How to do a Complete Brake Flush and Bleed - YouTube
August 20th, 2019 09:00 PM #17
- Jul 2014
- 31
August 27th, 2019 02:42 PM #18when is the time po sa car natin para masabi natin na need na natin ng brake flush? ung mileage kasi sakin mag 70k na, matagal na ko hindi nagcacasa, sa talyer lang ako madalas kapag change oil. help nman po. thanks
August 27th, 2019 02:53 PM #19
August 27th, 2019 04:58 PM #20
Ideally, every 2years. Humidity here is constantly high. Brake fluid is hygroscopic.
Automatic po Sir
