Results 1 to 10 of 10
January 28th, 2009 10:54 PM #1
Kanina lang nagpa change na ako ng brake fluid at brake pads. Pansin ko lang after parang more or less same lang ang braking power. pero mas naging progressive di tulad ng dati medyo malalim pa before kakagat. Ride is Honda City 1.5L VTEC CVT. 3 years na siya. So due for a change na.
Bendix yung pinalit. Bendix Standard to be exact. Kelangan pa ba ito i break in? Mag iimprove ba ang kagat nito in the long run? Nag OEM nalang sana ako or ok na rin itong Bendix?
may cracks yung old pads sa gitna. Sa front pads all of them has this crack in the middle. Yung pads naman sa rear disc brakes walang cracks kaso mas manipis na siya kesa sa harapan. Ano kaya ang dahilan bakit may cracks yung sa harapan? normal ba ito?
Thanks!
January 28th, 2009 11:43 PM #2
Wear and tear na yan. Bendix pads are good provided yun orig ang mabili mo. I use bendix in my 220E.
January 28th, 2009 11:51 PM #3
Brand new, mas manipis talaga ang centerline ng pads. Kapag upod na, that line really does appear (at least on pads I've changed out). Yep ok ang Bendix. Yan din gamit namin sa Benz. Wala kasing stock for my ride nung kailangan magpalit kaya tiyaga muna ko sa Rico brand (kahit Akebono walang stock).
January 29th, 2009 12:24 AM #4
i hope mag improve pa braking nito. baka kulang lang sa break in. sabi sa akin ng mekaniko glazed at denatured daw yung pads ko sa harap. exactly 28k km mileage ko before ako nag change ng pads
January 29th, 2009 02:57 AM #5
yun rotor natin over time nagkakarun ng grooves kinda like a record (yun nauna sa CD) kaya need pang lumapat yun pads sa mga grooves na ito. don't worry in a few kms lalakas din brakes mo same as when the car is new.
January 29th, 2009 03:54 AM #6
The main cause of brake pads cracking is overheating. This is almost always due to the driving habits of the individual. Do you always drive with one foot on the brake? Or,, Did you leave the parking brake engaged one day without knowing? Another cause is usng the wrong type of pad. If the OEM standard is semi-metallic and you use ceramics instead, then they're bound to crack. Always use the recommended parts. Sometimes must have been a faulty set of pads.overheating would cause the pads to crack.but the brake calipers would have to be seized to cause this also if pads have been on the car for years specially too much city driving they sometimes crack as they become brittle.
February 6th, 2009 04:13 PM #7
malakas ng ang kapit ng brake ko hehe ang lakas. napansin ko din silverish na yung aking rotors both rear and front. dati eh parang itim na mading grooves. ngayon eh silverish na. satisfied na ako
- Nov 2005
- 30
February 7th, 2009 08:28 AM #9If newly installed yun pads mahina talaga yun breaks. Hindi pa lapat na lapat yun pads sa rotor.
They have the term " bedding". A process para sa break-in ng pads.
You need to run the car up to 60 km then apply a moderate break to slow the car to 5km. Then repeat up to 10x. Interval of breaking is .3km to .6km to cool down the rotor.
Napansin ko lang after doing this procedure medyo lumakas ng konti yun break. But after a week of using the car saka ko pa lang naramdaman yun full breaking power ng bagong break pads.
February 8th, 2009 09:35 AM #10
there is this other bedding in procedure wherein youll have to ride your brakes while cruising for at east a minute then brake hard once to thrice. then cruise for 5 minutes to cool down the rotors then repeat at least 3 times. ito ang ginawa ko. dahil yung 2 days ko gamit brake ko eh nakikita ko sa rotor kalahati pa ng rotors ang silver. yung kalahati kakulay ng yung old pads pa ang gamit ko. meaning di pa lumapat doon
kaya yun nag bed in ako. normal din daw amoy sunog at may konting smoke pag mag bedding in. anyhow, max na yung brakes ko. dami ibat ibang procedure sa net na nabasa ko. and this is the one that i followed.
yung ibang technique kasi brake hard 10 times. di mo magagawa yan sa city. ang trapik eh. thats why i did the riding the brakes techniqueLast edited by suysuy; February 8th, 2009 at 09:37 AM. Reason: spelling
