Results 1 to 6 of 6
- May 2006
- 424
February 6th, 2010 02:02 PM #3
leaks - seals
hard steering - low or no PS fluid, low pressure (worn rings)
humming sound - low PS fluid
- May 2006
- 424
February 6th, 2010 06:08 PM #42003 pajero Fm po. Walang leak, pero may kabigatan ang steering compare sa other pajero..
Pag full left or right, may humming sound, is this normal? sabi ng mechanic the sound/vibration daw is due to the contact with the stopper.
Max yun fluid level. When the engine is on, the mechanic check the PS level by opening the cap, tumatalsik ang fluid. is this normal?
February 6th, 2010 06:55 PM #5
have your "mechanic" check the flow control valve, this valve is on the outlet port of the pump leading to the high pressure hose. it is spring loaded valve that serves as a pressure relief valve to allow recirculation of excess pressure to dump fluid back to the reservoir
- May 2006
- 424
February 7th, 2010 06:03 AM #6
Traffic!
