Results 21 to 30 of 30
July 28th, 2009 06:49 AM #21
tip,
that's what i was talking about, the thrust angle. the geometry of the four wheels have to be at a perfect or near perfect rectangle then the list i just mentioned to be followed. this practice had been done in years. if your really understand the steering principles, to include the Ackerman principle, you will get the whole picture, otherwise, it is not too late to learn.
jick
- Jul 2003
- 573
July 29th, 2009 12:29 AM #22that may be too technical for me, at least the principle of having the wheels travelling or trying to travel in the same direction will be enough. and the wheels moving in the desired direction when making a turn considering the
arc travel each wheel will have to take. Isn't that's why we have the
differentials?
July 29th, 2009 05:51 AM #23
tip,
that's the reason why there are technicians and there are mechanics or parts replacers.the Ackerman principle provides for the difference of distance travelled and the rotational speeds of the wheels of a car moving on a turn. on two wheel steering vehicles, each tire has different radii. this is done through the inherent TOE OUT ON TURNS (Ackerman principle). keep learning we have some progress here
jick
- Jul 2003
- 573
July 29th, 2009 09:53 PM #24guess that will be for the design engineers to figure out, and for the technicians to adhere to the desiogn or suggests some changes in practical applications.
- Apr 2009
- 536
August 4th, 2009 05:22 PM #25hello.... need you guys to share your experiences.
After alignment or camber. what did you notice, i mean 90 to 100% ba talga ang kain ng gulong niyo sa front wheel ay Pantay.
the reason for this question is after many years of driving.. i noticed mga front wheels lagi una napupudpod ang outer tire. just varies on the degree.
what do you think? and pag observe ko most vehicles have ( talking about the front wheels) d talaga pantay kain usually mas pudpod ang outer side.
- Jul 2003
- 573
August 5th, 2009 07:49 PM #26a properly aligned wheels will have balanced front wheel wear on the inner and outer side of the tyres. front wheel drive vehicles tends to wear out the outer side of the tire faster than the mid side. Tire rotation of front wheels to rear wheels helps to create a balanced wear on the threads.
August 9th, 2009 07:10 PM #28
August 9th, 2009 11:37 PM #29
Front usually wears faster than rear since they take most of the burden in braking since all the vehicles weight goes to the front wheels. FWD has a higher front tire wear since they also accelerate the vehicle. The more wear on the outer tire is due to concentration of friction during turning. Excessive outer tire wear (feathering of thread) can be due to excess toe in or camber problems.
- Jul 2003
- 573
August 12th, 2009 02:53 AM #30the recommendation for front wheel drive vehicles is to have toe-out, not toe-in for the front wheels.
Latest mileage:
