Results 1 to 5 of 5
July 17th, 2015 01:14 PM #1
Mga boss ano ba mas ok na method pag magpapalit ng power steering fluid saka brake fluid? Yung hinihigop or bleeding? Thanks!
- Nov 2009
- 3,474
July 17th, 2015 04:01 PM #2Usually walang bleed valve, kung meron man near the pump or the rack na mahirap dukutin. You have to siphon /pump then refill out from the reservoir while running the engine & turning lock-to-lock the steering wheel about 5x until the fluid becomes clear. A windshield washer pump is good tool for suckin out the fluid.
July 17th, 2015 05:44 PM #3
Napapalitan ko na sir using higop method. Nagtataka lang ako kung ok ba un or effective ba. Sa nakita ko kasi parang yung sa lalagyan lang yung nasisipsip, parang di nasisipsip yung mga nasa tubo which is un dapat ang ma drain. Hmm
- Nov 2009
- 3,474
July 17th, 2015 07:56 PM #4Effective yun basta paandarin mo makina to activate the PS pump & turn lock2lock steering wheel para umikot yung fluid. Makikita mo naman from murky brown yung container back to orig color.
July 17th, 2015 08:36 PM #5
Sabagay after sipsipin pinaikot manibela then sipsip uli. Same din sa brake fluid
Traffic!
