Results 21 to 30 of 40
- Jun 2016
- 1
- Mar 2014
- 901
June 26th, 2016 10:34 PM #22How will you know when is the time, to replace your gas type shocks?
Starmobile Up+Last edited by rodetor; June 26th, 2016 at 10:34 PM. Reason: Correction
- 52,517
June 26th, 2016 10:37 PM #23
- Mar 2014
- 901
June 26th, 2016 10:41 PM #24
June 26th, 2016 11:48 PM #25
for educational purpose, the softness or the stiffness of the ride when talking about shock absorbers depends on the ratio. typically, it is 50/50, for sportier rides 70/30 or 60/40. the first number is the jounce (compression) and the second number is rebound (extension). the pressurized inert nitrogen gas was added to eliminate the shock absorber fade. the fade results when the oil inside is repeatedly passed through the orifices of the valves in the piston and gets hot making the oil thinner. the pressurized inert nitrogen gas is used to raise the boiling point of the oil and to reduce the foaming action when the oil is passed repeatedly through the orifices. the shock absorbers should be of the same type between on the same axle and the same type all throughout.
- Aug 2012
- 2,767
June 26th, 2016 11:58 PM #26
- Mar 2014
- 901
June 27th, 2016 12:04 AM #27
June 27th, 2016 12:13 AM #28
did you know that shock absorbers need to be bled when gas goes into the fluid side? if gas goes into the wrong side, no matter what brand, no matter how new, the shocks never worked right.
- 52,517
June 27th, 2016 12:17 AM #29
June 27th, 2016 12:24 AM #30
for gas charged shock absorbers, release the piston( s/a came in compressed and held with a bale) with the unit upright like the position it will be installed. for non gas charged, compress the unit upside down, extend upright, repeat until the skipping while doing the procedure is eliminated
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
