Results 31 to 34 of 34
August 25th, 2003 11:06 PM #31
Ungas,
Kung yung shock absorber nga nilalagyan pa ng 'dual-action, telescopic ek ek', malamang hindi din makakaligtas ang brakes. hehehe. Mga tiga-marketing talaga. Minsan hindi ko alam kung nagpapatawa. :D
August 25th, 2003 11:30 PM #32Originally posted by Ungas
Naw... you can't be serious?! Is there such a thing as leading and trailing brake shoe? :whoa:
August 26th, 2003 01:23 AM #33Originally posted by mbt
the rear brakes only provide about 5% or 10% to the overall braking ability of the vehicle... the lion's share of the job is on the front brakes, so econocars can get away with rear drums with little loss in function
To answer the question, depende sa model nung drum brakes. The current rear drum brake systems on today's cars would provide better stopping performance than the front disc setups of the '70s. And today's front disc brakes are truly exceptional in terms of stopping power. Combined with the fact that between 60 and 90 percent of a vehicle's stopping power comes from the front wheels, it's clear that a well-designed, modern drum brake is all that's required for most rear wheel brake duty. Lamang lang talaga ang disc brakes dahil fully exposed sila sa outside air. This exposure works to constantly cool the rotor, greatly reducing its tendency to overheat or cause fading which is the only flaw I could think of para sa drum brakes. Under high braking conditions, like descending a steep hill with a heavy load or repeated high-speed slow downs, drum brakes would often fade and lose effectiveness. Usually this fading was the result of too much heat build-up within the drum.
Originally posted by scarab
....ok naman din ang stopping power ng drums eh. sa corolla cup nga nun sa BRC rear drums pa rin gamit, and those cars were driven the way that you will never be able to drive or abuse yours.
....mas sporty nga lang talaga tignan rear discs.
August 26th, 2003 05:08 AM #34
I think Drums Brakes have a more Tendency to Fade But Disc Brakes due to open air exposure reduces Fading..and More Biting power...
Daming issue ng SU7:grin:
Xiaomi E-Car
