Results 1 to 7 of 7
November 9th, 2002 03:45 PM #1
good day tsikot forumers! :D
i already a have K&N filter, 2.25" downpipe, freeflow muffler, stage 3 port and polish, shaved head, and lighten flywheel, now my problem is i have a hard time braking, parang hindi agad kumakapit, kaya pag red line ako, dapat layo pa pumepreno na ako, my mechanic told me to change my oem brakes to bigger ones, di daw kaya ng oem brakes baka madisgrasya lang daw ako, dapat daw mag disc brakes na ako front and rear! :oops: kaya ngayon di ko muna ginagamit kotse ko!
anong disc brakes ang kakasya sa kotse ko, LANCER 1993 Glxi? whole set (front and rear) sana including the handbrake cable, saan ako makakahanap, and magkano price range?
November 9th, 2002 04:08 PM #2
alam ko lang upgrading to a bigger rotor at a decent pad should be fine .
you dont have to go 4 disc for braking power , unless you
want to look good then be prepared to shell out a lot of money for the conversion , i
believe drum brakes pa ang likod mo right ?
sa locations and prices di ko alam , TSIKOT peeps paging !!!!
November 9th, 2002 05:53 PM #3
sir,
u mean, il just change my front disc brakes to bigger rotor? yung sa rear ko drum pa sila, what shud i do with those? may bigger drum ba? :lol: di kasi kaya ng oem brake system ko ang power ng makina ko! feel ko babangga ako! HELP! HELP! :oops:
around how much kaya aabutin kung palit ko buong brake system ko? ano mas maganda aftermarket or oem ng galant VR / lancer na JDM? :oops:
November 9th, 2002 07:47 PM #4
yung stock ng Galant VR should be sufficient enough for stopping power , ang di ko alam kung swak ito or mag fabricate ka pa sa conversion . may budget ka ba nito ?
check mo rin ang mga rotors ng Evo sa mga surplasan .
depende sa components ang gagastusin mo , yung pinsan ko sa 99 Mirage niya
nag 4 wheel disc brake siya , dati drum sa likod umabot ng almost $ 3000 . wala pang
labor yun kami lang nagkabit . bale 12" yung harap at 10.5 " sa likod at earls brake
lines din . so roughly mga 150,000 PHp yun pero high performance siya . HP Racing
pala ang brand nun .
- 400
November 10th, 2002 01:17 AM #5luckily maraming surplus parts dito sa pilipinas.
some jdm lancers of your car's generation came with 4 wheel discs, so your easiest bet is to find brakes from one of those cars. you'll have to scour the shops and yards though. i suggest you ask around at clubmitsu for help... someone might have your part in stock.
November 11th, 2002 06:11 PM #6
splerdu,
what particular car model? il try to scout, and hopefully makahanap! :D
- 400
November 16th, 2002 01:40 AM #7lancers din. yung jdm lancer gsr (1.8 dohc turbo, 4wd) saka yung jdm na lancer MR (1.6 dohc mivec) alam ko naka 4 wheel discs.
may nakita na rin akong itlog lancer na naka fto brakes, so i guess pwede yun, although kelangan palit ng mags kasi 5x114.3 yung pcd niya.
An EV for city driving sounds very good in theory and we've been seriously considering them...
All New Toyota Corolla Cross
