Results 41 to 50 of 74
November 22nd, 2014 06:55 PM #41
Interesting insight regarding inaccuracy. I travel 5000km/month. I guess I need to get something good.
November 22nd, 2014 07:56 PM #42
November 22nd, 2014 07:59 PM #43
May nabasa pa kasi ako jan ANSI Grade B accuracy. Hahaha. Nadali ako sa marketing strategy nila. Akala ko talagang accurate dahil sa label na yun.
- 52,698
November 22nd, 2014 10:16 PM #44
- 52,698
November 23rd, 2014 08:44 PM #46yespo.
but it's true. within their useful range, those springs have a linear relation with pressure.
what i do, is to mark the pressures that i use. never mind the others. and to make sure the dial cover doesn't move, i glue the edges.
i measure the "correct" tire pressure with an accurate gauge. then i use my dial gauge. whatever mark my needle points to, i write the "correct pressure".
- Aug 2012
- 2,767
November 24th, 2014 08:14 AM #47
- Aug 2012
- 2,767
November 24th, 2014 08:21 AM #48Accuracy vs Precision
Accuracy is how close a measured value is to the actual (true) value.
Precision is how close the measured values are to each other.
Examples:
Low Accuracy, High Precision
High Accuracy, Low Precision
High Accuracy, High Precision
- Aug 2012
- 2,767
November 24th, 2014 08:38 AM #49Here's my new tire pressure gauge. No time to test yet so I will just give my first impression of the Stetho-Gauge.
Build quality is good and feels solid. There is a serial number sticker on the gauge body. Each unit has a different serial number so no fakes here. Sticker says "International Patents Pending. Made in Taiwan."
The face of the gauge is very clear and easy to read. On the left side, there is a crest and the word "Hafner" underneath. I could only assume that it uses parts from "Hafner" (Philipp Hafner GmbH & Co. KG), a high-precision parts and equipment manufacturer in Germany.
The unit comes with a plastic storage case. There is a sticker with "How To Use" instructions at the back of the case. The packaging mentioned "ANSI Grade B Accuracy" and "Shock Resistant" among other features. There is instructions and illustrations at the back of the packaging.
November 25th, 2014 01:40 PM #50
magkano ang stetho gauge bro?
Yung sa uncle ko, stetho gauge, early 2000's pa nya yun. Until now, okay pa din, medyo hindi na nga lang accurate. Sa kalumaan na lang din siguro, around 10years na siguro yung tire gauge nya na yun. Ang estimate ko 30-32 psi yung gulong, sa casa ko pa pina-Inflate, halos 5 hours din kame sa casa so nung ininflate yung tire, malamang cold na.Ssa tire gauge ko (Elevo brand) 22 psi, sa kanyang gauge (Stetho) 26 psi.Last edited by andrewnathaniel; November 25th, 2014 at 01:44 PM.
Thank you!
