Results 11 to 14 of 14
- Apr 2014
- 231
- Apr 2009
- 533
October 3rd, 2017 06:10 PM #12If everything is new from the clutch master, slave , clutch disc, pressure plate and release bearing. and still slipping.
maybe:
1. Release bearing lock , I don't know what its called but its the two wires connected to the release bearing. on my experience one time mechanic failed to install one 'wire or lock'. kaya kahit hindi mo tapakan clutch umaandar or slips.
2.pudpod na yung dulo ng clutch fork, even if you adjust the rod of the slave hindi na niya kaya isagad.
- Jun 2006
- 1
- Apr 2014
- 231
October 8th, 2017 12:26 AM #14My hunch was right all along .. Hindi talaga compatible yung lumang pushrod sa bagong clutch master ko dati kaya nag slide siya ..
Bumili uli't ako ng brandnew but with the correct pushrod height .. Wala nang problema .. after installing, takbo agad, kahit ilang oras ang takbo, hindi na nag slide ..
It took me a year to diagnose that it was the replacement clutch master paired with the old pushrod all along was the culprit, I thought it was the clutch lining ...
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
