Results 11 to 18 of 18
- Nov 2002
- 162
January 9th, 2003 03:42 PM #11RS Sprint, san makakabili ng mga yan? mga how much?
How many liters do you need ba if you want to flush the brake system?
- 197
January 10th, 2003 10:59 AM #13
Alam ko nanginginig talaga ang brake pedal pag may ABS kotse mo at pumpreno ka nang biglaan.
Pa-inspect mo na rin yung brake system mo, lalo na yung brake pads at brake fluid. :D
- 197
January 11th, 2003 12:19 PM #14That's true, pero iba ang pulsing feeling ng brake pedal kapag nag activate ang ABS, at sa brake judder due to warped rotors.
Yung pulsing caused by ABS feels weird, non mechanical whereas ang brake judder due to warped rotors feels like may masisira na sa oto mo.
- Nov 2002
- 162
January 11th, 2003 11:26 PM #15CATS is the one in greenhills? Meron pa bang ibang place na available yang mga yan? Magkano ba tong mga to? Ano ang next best after ATE and MOTUL?
- 197
January 13th, 2003 09:47 AM #16Yup, CATS is the service station in Greenhills.
You can also try CASTROL RS brake fluid, same spec as the MOTUL RBF and ATE Super Blue. Not sure where else you can buy these. The ATE Super Blue costs about 600 per 500 ml, the RBF about 700 per 500 ml.
You need 1 liter of brake fluid to flush out most brake systems, so go figure.
- Nov 2002
- 162
January 13th, 2003 07:17 PM #17how much naman yung castrol?
when flushing can I use a different brake fluid first? Parang ang bigat sa bulsa pag pinamflush tong mga to.
d ba yung clutch brake fluid din nilalagay. Is it advisable that I use na din?
February 5th, 2003 12:35 PM #18
pre check this site:www.icarumba.com. surely, you wil learn a lot from this site.
Monk-owned R53
