Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Quote Originally Posted by CLAVEL3699 View Post
    hindi ako nagpalit nang rotor... reface lang pero parang ang lalim nang brake.
    Bleed na pero malalim pa din need pa talapakan nang malalim para kumapit. Ano kaya problem nito? Kulang lang ba sa bleeding.
    Gano kakapal pa yung rotor? Have you inquired about the price of replacements? Hows the brake master? Hindi pwede maadjust din yung brake pedal tolerance?
    makapal pa yung rotor pasok pa sa specs.
    tingin ko dun sa brake pedal tolerance.
    Jul 2006
    Re-bleed.
    Boss Clavel, your rotors may be out of spec (manipis) na.
    Boss pasok pa daw sa specs. hanap ako nang 2nd opinion.
    Jul 2006
    Bilis mong sumagot, di ko nahabol edit ......
    pero pacheck ko ulit... medyo kabado ako dun sa gumawa eh. hehehehe... subukan ko parebleed ulit, yung mekaniko ang papadyak ko hindi ako ehehehehe
    Jan 2008
    all disc ba yan or combination?? kung rear drum brake combination yan.. dapat adjust yung rear drum brake.. pads should be as close as possible sa drum (you should feel the pads almost touching the drum) wala sa kapal ng front disc ang taas or lalim ng brake pedal.. kahit manipis na brake pads mo pag naka disc brake ka hindi nag babago yung lalim ng tapak mo.. unlike pag drum brake lahat.
Brake pads replacement. Hindi pa din lapat
