Results 421 to 428 of 428
- Dec 2013
- 521
December 1st, 2023 09:29 PM #421
- Dec 2013
- 521
December 1st, 2023 09:32 PM #422Just to clarify things up with this, sa other brands like Brembo will usually put on their aftermarket brake pads ng who is the original manufacturer ng brake system ng certain car models, so yung naka lagay diyan na Akebono means Akebono was the original brake caliper and pads for that specific car model. Kaya sometimes naman sa other cars like Honda models yung makikita mo naman sa Brembo box is Nissin naman ang nakalagay na original brake system supplier ng car model na yun.
Kaya nakita mo doon sa sticker label ng Brembo may picture ng one whole brake system which is the caliper and rotor disc nakakabit together, what that means is who is the original stock brake system supplier ng car model na yun.
- Dec 2013
- 521
December 1st, 2023 09:37 PM #423Nope, the Brembo aftermarket division in China chose a new strategy which is to sell by volume sa masa end users. I already saw their prices on Shopee Thailand sobrang mura narin ng presyo nila they are trying to compete with Bendix level sa aftermarket na usually nasa P1,000~up lang na prices.
December 3rd, 2023 04:48 PM #424
- Dec 2013
- 521
December 18th, 2023 08:32 PM #425Yes isa din reason why Brembo brake pads are cheap is because a lot of them don't have what we call the slot, which is for cooling purposes of the brake pads friction material para hindi mag overheat kaagad and losing ng braking power and brake fade endurance & efficiency, kaya ang maximum operating temperature lng ng Brembo aftermarket brake pads ay only 370°C before hindi na kakayanin ng friction material.
- Dec 2013
- 521
December 18th, 2023 10:40 PM #426Without the brake pads slot ng Brembo aftermarket brake pads, once the pad material overheats it is prone to the material becoming brittle and cracking tapos Brembo aftermarket China dinadaya nila brake pads quality nila which is called dual layer meaning 1st half ng material is ok performance pero pagdating mo na sa 2nd half ng material mas worse or similar to Bendix General CT quality and performance na unlike Akebono na iisang layer and formula lang na friction material walang daya. Ang problem mo diyan is may 10% iron content yung Brembo brake pads yan lng only reason bakit may additional power yung initial na kagat sa brakes kaya mapapansin mo na maitim brake dusts ng Brembo dahil nga sa metallic content niya, masmalakas din wear and tear sa rotor discs.
- Dec 2013
- 521
December 18th, 2023 10:45 PM #427Without the brake pads slot ng Brembo aftermarket brake pads, once the pad material overheats it is prone to the material becoming brittle and cracking tapos Brembo aftermarket China dinadaya nila brake pads quality nila which is called dual layer meaning 1st half ng material is ok performance pero pagdating mo na sa 2nd half ng material mas worse or similar to Bendix General CT quality and performance na unlike Akebono na iisang layer and formula lang na friction material walang daya. Ang problem mo diyan is may 10% iron content yung Brembo brake pads yan lng only reason bakit may additional power yung initial na kagat sa brakes kaya mapapansin mo na maitim brake dusts ng Brembo dahil nga sa metallic content niya, x10 more kain niya sa rotor discs compared with original genuine car maker brake pads and Akebono. Tapos x2 masmabilis siya maubos versus Akebono brake pads due to chopsuey na two different types/layers of friction material and impure pa yung significant portion ng gamit nilang raw materials.
- Oct 2018
- 5
December 28th, 2023 12:06 AM #428JapanABC, can you suggest po where to buy original akebono brake pads and shoes around Metro Manila yung physical store po sana.
you don't buy a bike kasi may extra savings ka from somewhere... just buy a bike. explain later...
All New Toyota Corolla Cross
