Results 1 to 10 of 10
November 25th, 2008 06:22 PM #1
guys what do you think is the problem? kanina ko lang napansin mejo humina breaks ng hilander ko. Di naman nagbabawas break fluid. Nangyayare mejo mahina break tapos pag mga 1-2 seconds na ko nakatapak at nakatigil n ko mararamdaman ko bababa pa yung brake pedal. what do you think is the problem there? brake master? hydrovac? bleed lang?
November 26th, 2008 02:29 PM #2
feeling ko bleed lang. kelan nagsimula yan? nagpa drain ka ba ng brake fluid?
November 26th, 2008 02:59 PM #3
hopefully walang leaks sa 4 tires and lines. check mo bawat isang gulong baka nag-uumpisa na tumagas. and sana bleed lang nga. goodluck.
THE AUTO SPECIALIST
- Mar 2006
- 607
Tsikot Member Rank 4
- 2,716
November 26th, 2008 11:46 PM #5i agree ... most likely master cylinder ... happened to my esi ... needing overhaul kasi kinalawang na pala after 9 years ... replaced piston and o-rings
how often do we need to open the master cylinder for check-up anyway?
November 27th, 2008 04:24 AM #6
Check all the pads, if they are good check for leaks if none check the master cylinder and the brake booster. If the pads are good and there is no leaks it is more than likely the master cylinder.
November 27th, 2008 06:07 PM #7
month s ago cgro nagsimula. ill get the fluid drained this saturday and update you guys. di naman consistent n ganun. minsan lang 1 out of 20 na tapak sa breaks cgro frequency. sa tagas. di naman nagbabawas fluid.
- Jun 2008
- 64
November 29th, 2008 11:49 PM #8ganyan din ang nangyari sa pajero ko recently..sira din ang break, but the problem is pagnakatapak ako ng matagal sa pedal, unti unti syang bumababa at lumubog na ng tuluyan, sobra sa lambot. hnd makuha sa bleed.. ang ginawa ko pinalitan ko ng goma ang master kit, maga na kc at inoverhaul ko master cylinder ng liha. pansin ko kasi my maliit na bunge ang master cylinder kaya hnd sya naglalaro sa loob ng assembly, wlang hangin na lumalabas. pero ngaun ok na...hayz hirap!!!!
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 3rd, 2008 10:10 AM #10
nagpableed ako, pero same thing. muka nga master na. im gonna get the orig repair kit para sure. will keep you posted, ipon muna konti kakapagawa ko kahapon injection pump e.sakit.
Monk-owned R53
