Results 11 to 15 of 15
September 23rd, 2010 03:56 PM #11
sir ang alam ko pag butas na ang diaphragm yung brake fluid sa reservoir ay nauubus...sa case ng car ko di naman nauubus yung brake fluid sa reservoir yun nga lang sobra dumi and parang may fragments ng melted rubber.papa check ko na din lahat bukas for safety..mahirap na kasama ko lagi baby ko.tnx..
September 23rd, 2010 07:59 PM #12
mga sir some update...binasa ko yung manual and meron detail kung panu eh test kung ok pa yung brake system....
when engine is off depressed the pedal for several times then depressed and hold the pedal for 15 secs.. if the pedal sink may leak sa brake master cylinder,brake line,brake caliper..tapos when engine is off then depressed and hold the pedal then start the engine if the pedal is sink slightly ok ang booster and booster check valve.then while engine is idling depress and hold the pedal and off the engine for 30 secs. if the pedal height does no vary ok ang booster and booster check valve.if the pedal rises there's a problem on your booster or booster check valve.(correct me if im wrong).
iv'e done all the test and ok naman.cguro need lang e-bleed.update ko kayo bukas.tnx...
September 25th, 2010 09:33 PM #13
mga sir update lang po...ok na brake master cylinder...all they done is to replace the piston and the rubber..malambot na kasi yung rubber kaya nag kaka sinagaw..and also bleed properly.tnx...
- Jul 2003
- 573
- Feb 2003
- 1,038
September 26th, 2010 12:07 AM #15First of all congrats!! You acted promptly to one of the most important parts of a vehicle..Peoples lives are at stake on that items. Yes, it seems you have a very worn out brake master Piston assembly. As you've said sobra dumi na ng brake fluids..Kaya it's important to have at least every 2years change ng brake fluid para maiwasan ang ganyan problem. Most car manufacturers states that brake fluids will have to be change every 3years. Others says every year specially Brake fluids manufacturers..in my practice I go for every 2years..
Brake booster diaphraghm is independent on the hydraulics of the Brake system..so kahit me butas ang diaphragm you will still have intact fluids in the system.
