Results 1 to 5 of 5
June 6th, 2004 07:24 PM #1
nag bawas ang brake fluid ng strada ko hanggang kalahati na tsek ko sya mga 4 days ago puno naman, sinalinan ko na ulit hanggang ngayon di sya nagbabawas ulit 2 days ko nang gnagamit, di naman kumakabig & paranamang walang tagas . ano kya nangyari?
Tsikot Member Rank 3
- Dec 2002
- 636
June 7th, 2004 01:06 AM #2Could be a leak in the brake booster or a slight leak in one of the brake lines that only shows when hot. Get it checked and buy a brake master repair kit.
June 7th, 2004 02:02 AM #3
Ipaangat mo sa local gas station at tignan mo kung may leak sa lahat ng wheel cyl. and also check for leaks sa master cyl. and slave. (secondary). The fluid must have been going somewhere.
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 8th, 2004 11:15 AM #4yep, probably either a leak in the master. if not there then in the caliper or the drums.
- Jan 1970
- 396
June 10th, 2004 07:51 PM #5pag sa rear drum breaks ung leak, its very unnoticable since you can't see the lines.. ganyan nangyari sakin.
ganda sana, if we can exchange discharged batteries for fully charged ones, the same way we...
All New Toyota Corolla Cross
