Results 21 to 23 of 23
December 23rd, 2019 04:55 PM #21
- Jan 2007
- 2,224
December 23rd, 2019 05:01 PM #22Good to know you've found the culprit.
Medyo weird nga that pad wear was part of the initial diagnosis. Normally the hydraulic systems don't touch the pads at all, the furthest they make it is the pistons that push on the backing plates. Even when your pads are completely gone and you're pressing metal against the rotors it wouldn't cause brake fluid to leak.
Try pumping the brakes hard while someone watches the suspect area. Maybe dry it off beforehand then wrap a fresh paper towel around it. If mag leak ulit while pumping the brakes you'll easily see the paper tower soak up some of that newly leaked brake fluid.Last edited by Dr.Kamiya; December 23rd, 2019 at 05:04 PM.
- Sep 2019
- 107
December 23rd, 2019 05:34 PM #23
Thanks sir! Yep I'm already looking kung saan makakabili ng brake master medyo nahihirapan ako maghanap for 2015 mazda3 2.0L.
Tried to asked already sa Mazford 2 and Golden Isuzu pero wala pa daw sila nun. Still checking with other shops.
thanks sir! We will try that one as well.
My thoughts: Resale value is really about perception, and right now the perception is that a...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
