Results 1 to 3 of 3
July 11th, 2009 04:58 PM #1
mga pipolz, ask ko lang...
yun brake fluid ko ay nabawasan na (its almost middle of the MAXIMUM and MINIMUM levels); can i add brake fluid (from casa, left-over from the last PMS ko) sa car ko which has a non-casa brake fluid at the momnent?
pwede ba maghalo yun? thanks in advance for any advice.
July 11th, 2009 05:33 PM #2
pwede yan sir. what's important is the line should always
have blake fluid, irregardless of brand.
July 11th, 2009 05:38 PM #3
Generally you should leave it alone. if the brake fluid level is lower than before, it's because the brake pads have worn down a bit.
If you encounter abnormal brake fluid loss, have it check for leaks.
If you do have to top off, make sure it's the same type and grade of brake fluid.
Daming issue ng SU7:grin:
Xiaomi E-Car
