Results 11 to 15 of 15
- Apr 2008
- 99
- Apr 2009
- 429
August 14th, 2017 08:07 PM #12you did not mention if you changed your brakepads with new ones after resurfacing the rotors. Ideally, a new set of brakepads is to be installed after resurfacing. With the pic you posted, I can only surmise that your caliper piston and cylinder is probably dirty and sticking and need servicing. It is also wise to change your caliper kit and flush your brake fluid with a fresh one as this is hygroscopic (attracts water) and collects debris overtime. As with the caliper kit, I always use OEM. No further explanation needed
August 14th, 2017 09:27 PM #13
- Apr 2008
- 99
August 15th, 2017 08:28 PM #15
Suzuki JIMNY [merged threads]
