Results 41 to 50 of 71
October 4th, 2006 12:16 AM #41
I said 4 POT.Stock track 350z has 4 pot brembo caliper.Meron na bang 8 pot calipers?
October 4th, 2006 12:17 AM #42
Wow ngaun ko lang nalaman meron plang 8-piston na calipers kala ko dati pinaka malaki na ung 6-pistons!
masyado na ata mga bigatin yang mga yan! gusto ko lang naman malaman kung malaki talaga difference ng type-r na brakes from sir! kung sulit ba type-r sa 40k o mag ipon nalang ako ng pang brembo ko!
October 4th, 2006 12:21 AM #43
If you have already changed pads you may want to change to steel braided lines and see if it gives you better feel. Cross drilled rotors are good but have a tendency of cracking, you may want to try a slotted rotor instead. Try the EBC red stuff it's a ceramic pad that gives you great stopping power. I just switched my GSR to Powerslot slotted rotors OE size w/ the EBC red stuff two months ago and it can stop my car from 180kph repeatedly with no fade. The rotors are also made by Brembo for Powerslot.
October 4th, 2006 12:23 AM #44
mamar,
IMO,Brembo 4 pot is overkill in your current setup,YOu can get away with Type R.
*redorange,
Why steel braided lines will give him better feel?
October 4th, 2006 12:29 AM #45
san ba nakaka bili ng steel braided ose tagal nako nag hahanp nun wala ko makita!
ganto ba sinasabi mong ebc rotors!
mag kano kuha mo? kasi may nag bebenta sakin ng ganyan dati for 9k ata! hinde ko na gano maalala ehh!
and one more ting may nag sabi sakin dati na pag tuamgal mawawala daw ung kulay nyang ebc na rotors na yan! totoo ba un?
October 4th, 2006 12:32 AM #47
rubber lines flex and expand with pressure, steel lines have minimal flex and expansion so the pedal feel is more positive.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 4th, 2006 12:35 AM #48m_ron, actually the reply was meant towards ssaloon because he was mentioning the 350z at the transport show in manila held a couple of days ago. my reference to the 8 pot calipers were referring to the GREX system on that car.
SS brake lines improve feel because they do not swell like normal rubber lines when the fluid becomes hot.
go look at tar-ox. they make calipers with as many as 12 pistons if i'm not mistaken http://www.tarox.com/english.html
if you want the best tho, stick with AP Racing. they make some of the best brakes on the planet and i think are owned by Brembo also but make more performance inspired rotors and calipers. if you want to upgrade from brembos you install AP's
October 4th, 2006 12:47 AM #49
Powerslot is the rotor and EBC is the pad. If you are worried about the color of the dust it's not red just less of it. The part of the pad that touches the rotor is not red. The color really has nothing to do with your braking power anyways.
Rotor website:
http://www.powerslot.com/index.html
The pads I got for about $75 for the front wheels at racepages.com. The rotors I got for about $183 a pair from Racinglab.com if I recall correctly.
Affirmative. Aangat nga yun cover sa likod if ilalagay yun OEM rims. Badtrip. Sent from my...
2021 Honda HR-V/Vezel (3rd Gen)
