Results 11 to 20 of 20
December 2nd, 2011 12:19 PM #11
You might want to look at the Pirelli P4's, they're pretty cheap compared to the xm-2's. Tread looks very grippy.
- Apr 2009
- 543
December 5th, 2011 06:50 PM #12Might be that Pirelli's might not be as durable as tires built for hot climates. Maybe if budget problems I'll try kumho APT instead
of goodyear HP Aw or XM2.
Tsikot Member Rank 4
- Jun 2006
- 2,605
December 5th, 2011 07:13 PM #13I've used the XM1 on a minivan. Inflated with nitrogen. One blew out, side wall failed, at about 3 years and 30,000 kms. My dad's E150 also had 2 Michellins blow. So I'm wary of that brand.
No experience with the Good Year HP. But mos of our trucks (Elf aand Canters) use good yer. They last about 2 years. Better than the 1 year we used to get with Gagha. My city uses good year nct3, the stock tire, nothing great. But so far no problems after 2.5 years and 31,000 kms. Braking can be a lot better though.
December 6th, 2011 10:08 AM #14
Question: Would it be safe to install the Ecsta SPT's on a Grand Vitara? Currently running on Dueller H/T's (don't like them) and need to replace them asap. I was considering Yokohama Geolanders (either H/t or A/T) or Federal Couragia S/U's but the Ecsta's were at least P2,000 cheaper than these.
- Apr 2009
- 543
December 6th, 2011 06:54 PM #15Hi for my crosswind I'm also considering Goodyear Assurance fuel max 205 65 R15 threadlife is 580 seems better
than Wrangler HP AW 205 70 R15 440 threadlife. Michelin Xm2 is a little expensive but might have lower threadlife.
yun nga lang mas 65 lang yung assurance. Any insights?
thank you
December 6th, 2011 08:36 PM #16
Bro, yung Sportivo ko 2007, with Isuzu-supplied Michellin , 4 years na.And I travelled a lot in Mindanao roads!If you know what I mean. But of course since day one to date ...I pumped in Nitrogen instead of usual air on all the tires including spare. Honestly, it makes sense and very rewarding, take it from me. Good luck!
December 6th, 2011 09:14 PM #17
Check that the combined load rating of the tires equal the gross vehicle weight rating of the Grand Vitara... If it's just a little lower, just don't load the car to capacity.
Might actually be due to not checking inflation pressures. When you use nitrogen, you're still supposed to check the pressures regularly... At least every week, considering the poor condition of the roads here.
December 6th, 2011 09:41 PM #18
Thanks for the reply Sir!
Just one more question for reassurance. I googled the required load index & speed ratings of the Grand Vitara & the specs of the SPT's. I saw two different requirements for the GrandVit, one was 99T, the other said 100H. Since the SPT's ratings are 104V, am I right to assume that they meet, or even surpass, the minimum requirement?
December 17th, 2011 09:26 AM #20
Try Michelin Agilis instead of XM2 for your Crosswind. Rated for truck use. Higher load index, much stronger tires.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
