Results 1 to 10 of 34
- Jun 2005
- 35
July 20th, 2005 12:37 PM #1Guys, im getting these rims (18 inch / Chrome) for my Mazda Tribute. Im not sure what tire size to get cause ive been getting conflicting opinions. :question: The stock wheel and tire size of my car is 215/70 R16. All i know is i should get a tire size for the 18 inch rims that will match in diameter to my stock wheels. With that in mind, do you guys think i should go with 50 series or 45 series? What tire brands should i consider (yung di sobrang mahal, pero okay naman quality)? Thanks!
- Jun 2005
- 35
July 20th, 2005 01:15 PM #4
my bro has 265/50r18 tires on his V. wide tires look good as long as di sobrang wide.
- Jun 2005
- 35
July 20th, 2005 02:11 PM #6Okay, so 50 series then. But what about the width? Do i have to get a 265/50 R18 or can i just get a 255, 245 or even 235? I dont want to sacrifice the turning eh. Tsaka relatively mga how much pala 1 set of tires na ganito size?
- Jun 2005
- 35
July 20th, 2005 04:13 PM #8gano kakapal lang dapat (235, 245, or 255) para hide sumayad sa fender pagtodo liko?
July 20th, 2005 05:05 PM #9
Try this link out:
http://www.miata.net/garage/tirecalcold.html
A good estimate of the tire size would be 255/50R18, or even the 265/50R18 BlueBimmer mentioned.
- Feb 2003
- 324
July 20th, 2005 05:08 PM #10i have 255/55-18 falkens ziex z04s on my escape. rims are 8.5x18 Rays G-Games 77S w/ 45mm offset. the correct original tire size and diameter for the tribute/escape in the US and Japan are 235/70-16s or approx 29inches diameter, just like 255/55-18s. Their differential ratios are 2.93 just like ours so I can't figure why Ford Philippines put on 215/70-16s (28" diameter). Maybe to make the speedometer/odometer to read faster para perceived better mileage?!?
Toyo and bridgestone have similar sized tires. Once you have your new tires&rims fitted you'll have to lower your ride as it'll look really weird w/ low profile tires and lifted look.
Expect to have a stiffer ride even without the lowering springs.
BTW, i had 7.5x18s before w/ the 255/55-18s but they looked too narrow for the tires. w/ the 8.5x18s, the tires' sidewalls are flush w/ the rim whereas before they were bulging slightly out.
If budget permits, try 19" rims! Parang bitin itong 18s.
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
